Home > Maintenance & Modifications > Door studs |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 |
Gents
Can anyone help with the name and part number of these studs shown in the diagram Thanks Gavin |
5th Aug 2014 8:41am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Plastic Rivet
MWC9918PMA - black MWC9918LCS - pale grey MWC9918LOY - dark grey 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Aug 2014 9:34am |
Brilliant - thank you Martin
5th Aug 2014 9:49am |
Just looked at a photo of these on line - how are they actually fitted ?
Thanks Gavin |
5th Aug 2014 10:57am |
Hi Gavin, are they missing on yours or some other problem?
You push the bit of the rivet with the legs through the door card into the door frame (requires a wiggle, of the rivet). Then push the pin into (but not through) the rivet to lock the legs in place. 1988 90 Td5 NAS soft top 2015 D90 XS SW Last edited by Martin on 5th Aug 2014 11:03am. Edited 1 time in total |
5th Aug 2014 10:59am |
KarlMD Member Since: 26 Sep 2013 Location: Staffordshire Posts: 36 |
There is a small dowel in the centre that you need to push through, be careful not to lose it. When you re-fit them, you just push the dowel back in to spread the clip out.
5th Aug 2014 11:02am |
