Home > Maintenance & Modifications > Can a Series 3 take H4 bulbs, with mods if necessary?
BigWheels
I would like to fit my prospective Series 3 with H4 bulbs. Would I need to change the fuse, use a more powerful battery &/or anything else? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #348875 1st Aug 2014 7:35pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Quite a common upgrade, when I had my series 3 all I had to do was remove the sealed beam headlights and fit halogen units in there place.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #348893 1st Aug 2014 9:07pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
They are basically a plug and play upgrade. All you need to do is buy the '7" Halogen upgrade kit', which most parts suppliers sell, eBay, classic car specialists etc.
eg: http://www.ebay.co.uk/itm/LAND-ROVER-SERIE...3a74a672d3
And then remove the old sealed beam headlamps, and fit these in place of them and plug the connector straight on. You may want to have a look to see what condition the headlight retainers/bowls are like, as they may need replacing if they are badly corroded. Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #348900 1st Aug 2014 9:38pm
BigWheels
I have my OE Defender ones after fitting the Wipac clear lens type (latter would look too modern). Would they do with H4s? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #348953 2nd Aug 2014 10:12am
PCA42
Yeah should fit no problems. Thumbs Up Pete
Post #348983 2nd Aug 2014 12:25pm
BigWheels
Thanks, I'll get the Osrams put in. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #348997 2nd Aug 2014 1:13pm
