![]() | Home > Technical > Extremely noisy fan |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Mine does it too, even from cold. Sounds like the old fixed fan engines.
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1029 ![]() ![]() ![]() |
My puma 2007 does the same, feels quite gutless as it sounds like the engine using all it's power to make the noise Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Do you guys have aircon?
My Disco3 does they same when it is warm like now and driving slowly and at start-up. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Yup,
![]() Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Spookytooth Member Since: 19 Jan 2014 Location: Lincolnshire Posts: 202 ![]() ![]() ![]() |
Air con fitted, however, does not have any impact on fan roar whether on or off
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1956 ![]() ![]() ![]() |
The viscous fan will come into play as and when needed, when towing my caravan it will do it in 1st 2nd
May be worth having if checked I am sure they are not that expensive either ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Is the Puma fan not electronically controlled like with the D3? Roel
2.2 TDCI fan is viscous. Aircon fan is electric.
Ok sorry for the confusion. The Disco 3 only uses 1 fan for both. Roel
I think my issue is that the viscous fan is coming on strong when its not needed. It comes on with a jet engine roar when I am solo, neither carrying nor towing anything and have done nothing but drive a few miles up the road. In this hot weather it starts to roar almost straight away
Does anyone know what or where the fan get its signal from in order to decide how hard to work as I am beginning to think that's where the problem lies and sorry to go on does it make sense that the fan roaring can also account for the apparent power drop and increased fuel consumption. Thanks |
A viscous fan has no input or signal, imagine two sets of vanes independent of each other one attatched to the engine the other to the fan in a container surrounded by a liquid that gets thicker as it gets hotter. 2023 Defender L663 V8
That's correct and that's why it's weird that it does it when the engine is cold.
So am I correct in saying the signal for the fan to speed up is the liquid (assume fan clutch fluid) getting hotter? Can I ask what causes the liquid to heat up, is it coolant temperature, engine load or something else. Thanks
The liquid is a silicone liquid which is thin when cold. Heat from the engine causes the liquid to heat up and as it does so it gets thicker. At this point the liquid 'binds' the fan blades and the fan pulley as one via a clutch arrangement. The engine gets cooled by the rotating fan, liquid cools down, gets thinner and drive to fan is disengaged. Thats the theory, but a knackered viscous coupling (clutch) will either not engage causing overheating or not disengage causes the fan to be engaged all the time which uses more fuel. As an aside its a similar system to that used on the Freelander to engage 4WD.
