Home > Puma (Tdci) > Engine oil leak keeps returning |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Do you have excess crank case pressure?
I have heard of an example of a low mileage 2.4 puma that was blowing oil out of the plastic cover (in the front timing chain cover) and the fault was found to be excess crank case pressure. The engine was blowing a lot when the oil filler cap was removed with the engine running. The car had only been used on frequent short trips and it was though that this cause the rings not to seal correctly due to carbon build up. The solution at the time was a full strip down and clean but I would have tried some magic potion and a good thrashing of the motor...... 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
11th Jul 2014 9:22am |
EddieL Member Since: 07 Jul 2014 Location: S Wales Posts: 10 |
That describes it exactly! The car only does short trips and it was again the plastic bung / plate causing the problem. My mate at the garage also mentioned the excessive pressure when he removed the breather pipe.
Can anyone recommend a good magic potion / flush and what is a good run - motorways or just get the revs up for a certain amount of time?? |
11th Jul 2014 6:58pm |
Another thought - would the dreaded EGR add to the coking up problem?? Especially with my short trips?
11th Jul 2014 7:15pm |
zeerover Member Since: 11 Jan 2009 Location: Ghent Posts: 16 |
Injector seals gone. |
12th Jul 2014 1:05am |
Would a failed injector seal cause back pressure? Or are you saying a potential leak from the injector seal?
12th Jul 2014 4:08am |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 |
EddieL - did you confirm the cause of your problem?
Cheers Mike |
29th Jul 2014 12:48pm |
It was leaking from the bung again so have sealed it back down and given the engine a good flush through and new oil. To be honest it does very short trips so I can't help feeling it may be to do with this so keeping my fingers crossed!
Cheers Ed. |
29th Jul 2014 9:57pm |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 |
I have a leak in my vacuum pump seal (high pressure oil spray on the underside of the bonnet on the passengers side??? ) Can anyone tell me if this is a big/expensive job to fix? Do I need to get it fixed straight away?
30th Jul 2014 1:55am |
Yes they do cause back pressure and oil consumption. |
8th Aug 2014 1:17am |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 |
[img]https://www.defender2.net/gallery/albums/userpics/14958/0_200_1235_014712384.jpg[/img]
[quote="EddieL"]I have got my local garage looking at it and it doesn't seem to be vac pump as that looks clean. I would say that doesn't look like high pressure spray more one that is getting onto the various belfs and pulleys and getting chucked around. When viewed from below its all over the front axle and n/s chassis rail. When this last happened it was coming from a plastic blanking plate on the front of the engine (I would call it on the front timing chain / belt cover but my description may be wrong!) and it is looking like it may well be coming from here again??? The truck is at the garage at present so can't do photos but will update if / when this problem is resolved. As always any thoughts great fully received. Cheers Ed.[/quote] May be this part 3 but I dont know how it is fixed? [img]https://www.defender2.net/gallery/albums/userpics/14958/0_200_1235_014712384.jpg[/img] |
8th Aug 2014 10:39am |
if the bung has been out a couple of times , maybe the flat cover is out of shape a bit , we have had to put a small bead of sealer round the seal a few times to get them to seal |
8th Aug 2014 10:44am |
I can't include a pic.
So I think there's a leak from the cover fuel pump (LR004639) on the cover cylinder front (LR004403) |
8th Aug 2014 10:53am |
