Home > Puma (Tdci) > Rear drive shaft shims?
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
Found there is no shim behind the circlips just behind the dust cover on both rear drive shafts whereas these shims are present on the front drive shafts. I've looked at the manual and cannot see them there either. There is about 3mm of float in the rear drive shafts - is this normal?
Post #347615 25th Jul 2014 8:35pm
landy andy
Yes. No shims on rear, just on the front Thumbs Up
Andy
Post #347647 26th Jul 2014 5:53am
Generaldej
Thanks Landy Andy
Post #347669 26th Jul 2014 8:12am
Caterham
And if only one of the front shafts had shims and float in the other what problems (if any would you expect
Post #434323 28th Jun 2015 5:54pm
Retroanaconda
The shims are there to set the position and end float of the CV joint within the swivel housing and stub axle. Differences in the machining etc. will mean that there may be different numbers/thicknesses of shims on either side.
If you're concerned measure the end float with a DTI as per the manual and re-shim if necessary.
Post #434348 28th Jun 2015 6:57pm
Caterham
DTI gauge seems like quite an accurate means of deciding how many shims are needed - which I'm sure is right yet the axle etc all seems pretty crude / basic.
If it's not done accurately what sort of problems would have expected? I'll be another look tonight (assuming I'm not falling asleep on my feet).
Post #434481 29th Jun 2015 7:44am
Retroanaconda
A DTI is also specified for doing pre-Td5 wheel bearings, though nobody really bothers as they are very easy to set by 'feel'.
In reality unless the end float of the CV is miles out it is unlikely to cause major issues, if there was misalignment between the CV and the swivel pin axis it could cause damage to the CV or perhaps clattering about as the CV moved on turning the steering. Off the top of my head I am not sure what the specified end float is, however I suspect that 'very slight play' is probably about right. By that I mean the CV is restrained by the circlip/shims but not so tightly held that it cannot freely rotate within the stub axle bearings/bush.
You could probably get away with using feeler gauges to measure the end float by pulling the CV out as far as possible and measuring the gap between the circlip and the end of the drive member. Then choose shims to suit, leaving the required end float.
Post #434548 29th Jun 2015 11:43am
Happyoldgit
You've done it again Wayne, jumped from one issue to another Rolling with laughter Steve.
http://forums.lr4x4.com
Post #434579 29th Jun 2015 2:41pm
Caterham
Retroaraconda - thank you......clatter you say - hmmmm
Steve, would seem I have plenty to choose from. Thumbs Up
Shopping list at present consists of new front axle, clutch master cylinder and checking the turbo wiring.
Keep you busy and penniless these motors.....
Post #434642 29th Jun 2015 7:02pm
munch90
Caterham , take it you still haven't got someone to drive it and get there opinion Rolling Eyes
Post #434645 29th Jun 2015 7:05pm
Caterham
Well I have and the response I think was a very non committal 'something ain't right 'and then we quickly moved on.
I know I probably seem like a complete nutter but in the c20 cars I've owned I have never moaned about one not being right and one of those was a puma defender so although I don't know for sure what's wrong I am very sure something ain't right.....i know that doesn't help any!?
Post #434650 29th Jun 2015 7:19pm
Happyoldgit
What about getting someone off the forum to drive the thing? Steve.
Post #434688 29th Jun 2015 8:38pm
munch90
GET A SECOND OPINION
Post #434695 29th Jun 2015 8:54pm
