Home > Puma (Tdci) > Advice re. imminent purchase
I am looking at an 07 plate 110 XS double cab with the Puma engine which I have been offered (its first MOT is taking place today). It looks good and the price is right. Before I commit, could someone in the know tell me:-
1) What mods etc should have been carried out to an early TDCI (eg sump change, clutch upgrade etc) and is there any way I can verify these visually (I guess that LR service records will show, but they probably won't tell me unless I buy it and book it in for a service).
2) Are there any known issues weaknesses I should be aware of?
3) Who makes the best and most suitable swing-away spare wheel carriers?
The vehicle in question has 57k miles on the clock, 33k put on in the last year (I know the present owner well) and has been regulrly services by an independent, non-Landrover-specific, garage with a good reputation.
Sorry for all the questions, but I am new to the Puma Defender having been a TD5 Disco 2 man up to now.
Thanks.
Post #34757 21st Jun 2010 11:20am
bob neville
I can answer number 3 - Sonic3d (Matt) of this very forum Thumbs Up
Have a look in my gallery for other pics.
Bob
Post #34758 21st Jun 2010 11:30am
Grockle
ask what recalls have been carried out on the truck 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #34762 21st Jun 2010 12:01pm
That looks exactly what I had in mind, thanks.
Post #34763 21st Jun 2010 12:07pm
None in the last year at least. What recalls should have been carried out on an 07?
Thanks.
Post #34764 21st Jun 2010 12:08pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
The only recalls to date is the sump on an 07 some others have had a recall on the flange in the hand brake drum....but that was on late 07/08
Sonic wheel carrier is about the best you will get ...
The known issues weaknesses you should be aware of is the clutch...but my last one seems fine Thumbs Up
Ask you mate to get all the service and warranty records of L/R they will print them out for him Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34768 21st Jun 2010 1:48pm
Grockle
Thanks.
what Karl said plus vac pump 2.4 90 XS
Post #34769 21st Jun 2010 1:51pm
Thanks for the advice everyone. Is there an easy way visually to tell the revised sump from the first type?
If the clutch and/or vac pump needs changing, is it likely that they would be done FOC despite the waranty period having expired? I guess if they were recalls they would, but clearly they are not actual recalls.
What was the issue with the handbrake drum flange?
The Sonic wheel carrier looks the business! I like the way that is attaches only to the rear crossmember, and not the body. I presume that the gas strut holds it open/closed. Can it phsyically be locked (ie padlock type locked) in the shut position to prevent the tailgate being opened?
Thanks for all your help and advice! If I do buy the vehicle (which looks likely at the moment provide Mr Bank Manager doesn't object) I will post some pics in due course.
Post #34774 21st Jun 2010 3:46pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You don't need to worry about any of the recalls. If you take it to a LR dealer, they will check all the recalls anyway.
The sump has a chunk out of it (to stop it hitting the diff case), the handbrake was a leaking transfer box seal that rendered the brake less efficient (cue sarcastic remarks about how rubbish they are anyway), the engine gets re-mapped (to address loss of power). Those are the recall items but LR will flag those to you automatically.
The additional one to check are whether it is still running the original vac pump. If so, expect it to fail at some stage - it doesn't stop the vehicle but makes a mess.
Some Defenders have had issues with gearboxes and there was an inherent weakness in the original clutch. That said, mine is still going and that's an '07. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #34779 21st Jun 2010 4:13pm
bob neville
The strut holds the carrier open and helps with opening - Defender wheels/tyres are heavy.
The carrier can be locked with a padlock.
Bob
Post #34780 21st Jun 2010 4:15pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Hi Bob where were you this weekend?? we had a fridge full of cold cider at the show with your name on it Thumbs Up
Post #34806 21st Jun 2010 8:04pm
Is there a way to tell an original vac pump from a later (double seal?) pump - other than the former spewing oil under the bonnet?
Post #34837 22nd Jun 2010 10:00am
fekete
B/W The latest one i had fitted was number 30 G 09 written on the pump that was in September 09 hope this helps Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34848 22nd Jun 2010 10:24am
bob neville
Stuck in the garden under a fridge full of cold cider with my name on it Laughing
Bob
Post #34861 22nd Jun 2010 11:16am
mse
There were a few other recalls.
One that springs to mind is the brake line and heat shield and another service action propshaft grease nipples Mike
Post #34879 22nd Jun 2010 4:14pm
