![]() | Home > Puma (Tdci) > Speed and EGT |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
Loaded to the rafters you shouldn't really be doing 140kmh ![]() Doing 120kmh loaded, my EGT sits around 500-550C, long uphill and it climbs to 597C. Not sure if it has gone over 600C yet.
Be careful, these will invalidate your warranty if yours is still under the original LR warranty! |
mrblue Member Since: 01 Jun 2010 Location: Centurion Posts: 6 ![]() ![]() ![]() |
Hi naks,
Thanks for the info; yes when loading we try and keep the COG as low as possible, no roofracks! Regarding the Intercooler and chip tune, Land rover will invalidate the warranty, but interestingly this mod was recomended by one of the sales guys at a Land rover dealership(not going to say which one) and the recomendation is to use Elton from superchips. |
I would NOT listen to anything stealers have to say - these monkeys don't know the first thing about landys. Someone recently met a stealer workshop manager who claimed that the Defender's drivetrain is 60/40 4WD ![]() So, the stealer tells you it's ok. Then six months down the line your turbo blows because of an oil hose that a stealer mechanic did not tighten properly after a service. I guess you see where this is going? How much you want to bet that same poephole will turn around and tell you because you put a non-LR intercooler and remapped your Puma, that your warranty is void and you will have to fork out R15K for a new turbo? Also, I think he meant Elton from Turbochip: http://www.turbochip.co.za/ ![]() |
Yes Elton from Turbochip...Thats him, and Yes Land Rover will invalidate the warranty, no question...
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Remaps, chipping etc WILL invalidate your warranty - LR wrote to all dealers to inform them of this.
As for intercoolers, im not so sure actually - either way, just get the dealer to put it in writing ![]() |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Hi all!
How are you measuring the EGT? Do you have some specific instrument for it? Or do you take some signal of some sensor on exaust? Because I only know that this instrument is used in airplanes! But is an important data for cars too. regards! |
Gabriel, I have the Madman EMS2 system fitted. Many Defender owners in SA fit this unit, since it is manufactured locally by a landy expert (www.landyonline.co.za). ![]() Click image to enlarge BUT, you can also do this with a temperature probe and simple LED display, quite cheaply actually. The EMS system was designed for Defenders, and monitors EGT, Oil Pressure, Coolant level, Coolant Temperature and also transfer box oil temperature. |
Very Very interesting Naks!!!!
Bad that we still don't have it in Brasil! thanks for the information! and how are the world cup? enjoying it? Go Bafana Bafana!!!!!!!! Regards! |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
mrblue - welcome!
Gabriel - the World Cup is an awsome experience yes... cheers all! www.ralton.co.za |
