Home > Puma (Tdci) > Speed and EGT
mrblue
South Africa 2009 Defender 90 Puma 2.4 CSW Alpine White
Speed and EGT
Hi There, I am new to this forum so be be gentle with me.....
Regarding long extended trips in the Puma has any one been able to measure EGT? We often do trips of 600Km at a time, with the Defender loaded to the rafters and sitting at maximun speed of 140KM/H for a couple of hours.
I will be fitting a larger intercooler soon as well reprogrming the chip.
Cheers,
Eric
Post #33472 2nd Jun 2010 8:49am
Naks
Re: Speed and EGT
Loaded to the rafters you shouldn't really be doing 140kmh Whistle
Doing 120kmh loaded, my EGT sits around 500-550C, long uphill and it climbs to 597C. Not sure if it has gone over 600C yet.
Be careful, these will invalidate your warranty if yours is still under the original LR warranty!
Post #33495 2nd Jun 2010 12:26pm
mrblue
Hi naks,
Thanks for the info; yes when loading we try and keep the COG as low as possible, no roofracks!
Regarding the Intercooler and chip tune, Land rover will invalidate the warranty, but interestingly this mod was recomended by one of the sales guys at a Land rover dealership(not going to say which one) and the recomendation is to use Elton from superchips.
Post #33503 2nd Jun 2010 2:00pm
Naks
I would NOT listen to anything stealers have to say - these monkeys don't know the first thing about landys. Someone recently met a stealer workshop manager who claimed that the Defender's drivetrain is 60/40 4WD Shocked
So, the stealer tells you it's ok. Then six months down the line your turbo blows because of an oil hose that a stealer mechanic did not tighten properly after a service. I guess you see where this is going?
How much you want to bet that same poephole will turn around and tell you because you put a non-LR intercooler and remapped your Puma, that your warranty is void and you will have to fork out R15K for a new turbo?
Also, I think he meant Elton from Turbochip: http://www.turbochip.co.za/ Thumbs Up
Post #33505 2nd Jun 2010 2:06pm
mrblue
Yes Elton from Turbochip...Thats him, and Yes Land Rover will invalidate the warranty, no question...
Post #33509 2nd Jun 2010 2:45pm
mse
Remaps, chipping etc WILL invalidate your warranty - LR wrote to all dealers to inform them of this.
As for intercoolers, im not so sure actually - either way, just get the dealer to put it in writing Thumbs Up Mike
Post #33540 2nd Jun 2010 6:18pm
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi all!
How are you measuring the EGT? Do you have some specific instrument for it? Or do you take some signal of some sensor on exaust?
Because I only know that this instrument is used in airplanes! But is an important data for cars too.
regards!
Post #34703 20th Jun 2010 2:55am
Naks
Gabriel Boff wrote:
How are you measuring the EGT? Do you have some specific instrument for it? Or do you take some signal of some sensor on exaust? Because I only know that this instrument is used in airplanes! But is an important data for cars too.
Gabriel, I have the Madman EMS2 system fitted. Many Defender owners in SA fit this unit, since it is manufactured locally by a landy expert (www.landyonline.co.za).
BUT, you can also do this with a temperature probe and simple LED display, quite cheaply actually. The EMS system was designed for Defenders, and monitors EGT, Oil Pressure, Coolant level, Coolant Temperature and also transfer box oil temperature.
Post #34709 20th Jun 2010 8:59am
Gabriel Boff
Very Very interesting Naks!!!!
Bad that we still don't have it in Brasil!
thanks for the information!
and how are the world cup? enjoying it?
Go Bafana Bafana!!!!!!!!
Regards!
Post #34718 20th Jun 2010 4:57pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
mrblue - welcome!
Gabriel - the World Cup is an awsome experience yes...
cheers all! www.ralton.co.za
Post #34736 21st Jun 2010 4:58am
