Home > Maintenance & Modifications > Breathing easier - added air intake
Page 2 of 4 <1234>
Timo K
Finland
It's a LHD that I imported from Germany to here in Finland.
Here's a bad quality pic but I guess it shows roughly how it looks:
Post #346412 20th Jul 2014 8:44am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Timo K wrote:
Points to you for having the balls to cut a hole like that in your front wing... But I tihnk with that mod you completely negated any benefit of a RAI. My basic understanding of fluid dynamics would say that air is also one of these things that follow the path of least resistance, so if that piping that you added is near the diameter of anything else before the turbo, it'll suck in most, if not all of the air through that.
On the 300Tdi atleast, the standard piping for the air intake is idiotic, which is why I did this to mine:
The effect was profound. I wasn't expecting much, but the difference was significant.
Yours is neater though, I only had some scrap bits to go with. Smile
When he 'needs' the RAI he can block the new intake. For everyday driving the new intake provides the air.
Post #346413 20th Jul 2014 8:45am
K9F
Using the heater blank on the wing sounds a discreet and viable option perhaps? It could possibly be used in conjunction with a snow cowl. Either way I am inclined to agree that fitting a second auxilliary larger diameter inlet would negate the necessity or requirement for a RAI at all. Using the blank heater inlet is also above the recommended wading height anyway so strengthens the case for binning the second RAI completely. Drastic measures and balls the size of watermelons Matt. I take my hat off to you.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346414 20th Jul 2014 8:50am
Timo K
Finland
True enough, but if there's no waterproofing of the system elsewhere, what was the benefit of the RAI in the first place?
Post #346424 20th Jul 2014 9:09am
K9F
None whatsoever! A raised air intake is not a snorkel unless it's been thoroughly sealed correctly! Common mistake. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346426 20th Jul 2014 9:11am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Is this what this is doing from Nakatanenga ?
http://nakatanenga-tours.de/shop/article_O...DOAITD4%26
Can't really work it out from the photo. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #346433 20th Jul 2014 9:33am
ZeDefender
Okay - I'll try to make this as clear as possible...
1) I want to refit the RAI to avoid dust and snow.
2) The RAI restricts air flow
3) I have increased air flow for hot/fair-weather use by adding an intake
4) I realise this negates the point of having an RAI while the extra intake is open
5) but 4) doesn't matter under normal use and I can leave the RAI fitted for when I need it
6) When I need the RAI to keep things clean under dusty/snowy/ really wet (not wading) conditions, then I just block the auxiliary intake off with a rubber plug (just ordered the rubber). Then I can pretend I just have an RAI.
Unfortunately, there is very little room under a LHD A/C Puma bonnet. Big tubes just don't fit along the normal intake path and there's no room to feed them over the top - this would have been my first choice.
Just needed to clarify the concept Wink Tell someone you love them today because life is short.
Post #346443 20th Jul 2014 9:58am
ZeDefender
By the way Mal - just waiting for more Sikaflex to seal the RAI properly Laughing Tell someone you love them today because life is short.
Post #346444 20th Jul 2014 10:05am
carrotbay
I like the concept and sounds like a good idea .. the way you've done it looks good too. Thumbs Up
However, I don't want to drill a hole in the wing .. also have a good change of messing it up, so was wondering if the Nakatanenga solution would do the same thing for me. I just want to be able to increase the air flow by utilising the heater vent on the top of the wing and the standard air intake on the side.
(I don't have a RAI .. nor have the need for one in my circumstances.) 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #346445 20th Jul 2014 10:07am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Thumbs Up
Exactly what i looking at yesterday, Td5 rhd abs+clutch+steering = not much room i am thinking of two 70mm pipes one from the standard intake and one from the blanked wing top panel. ZeDefender brave man Thumbs Up Range Rover p38 4.6 99 lpg(gone Sad )
Post #346451 20th Jul 2014 10:17am
ZeDefender
Well, it's been 33 degrees here and after a nice quick run on the motorway with the RAI fitted, everything is working just fine. No additional noise from the new intake and definitely no air restriction even under significant load (up hills at 150 km/h).
Just a couple more pics with the RAI (sealed well enough for now) - the second photo shows just how small the intake area is Shocked
After we've had some serious rain I'll hook the air filter out and have a look inside...
Have a good evening all Thumbs Up
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #346560 20th Jul 2014 6:23pm
ericvv
Ahem,....
Could not stop myself Rolling with laughter You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #346572 20th Jul 2014 7:19pm
borderterrier
Re: Breathing easier - added air intake
ZeDefender wrote:
Hi all Smile
I wanted to refit my RAI but with "restricted breathing" problems in the past (high temperature, high altitude, high speed) and now the bigger intercooler and hybrid turbo sucking even more air, I was a bit worried. There have been a number of air intake mods in the past but with LHD and aircon, I decided to take the bull by the horns and add one...
What pipe and end fitting did you use Ze?
Post #346593 20th Jul 2014 8:10pm
munch90
I have thought about adding a extra intake
but don't really want to cut hole in bodywork , maybe will make something for blanked heater intake ( rhd ) and won't be fitting a snow cover thing ( each to there own etc but don't like the look of them )
would make a baffled box with a drain to fit under the wing on the heater intake
Post #346601 20th Jul 2014 8:30pm
ZeDefender
If only you had one my size Rolling Eyes Thumbs Up
The pipe is 80mm and comes from Ramair:
http://ramair-filters.co.uk/ducting-automo...d-cap.html
The end piece is loose so I "moulded" a mesh over it and glued the pipe over that (stretched quite nicely) Thumbs Up Tell someone you love them today because life is short.
Post #346607 20th Jul 2014 8:39pm
Page 2 of 4 <1234>
