![]() | Home > Maintenance & Modifications > Battery kill switch |
turn battery switch off within 15 secs ( I think it's 15 maybe 10 ) of turning off ignition
I would say not really a good thing to keep turning it off how rarely do you use it ? |
666PXX Member Since: 05 Mar 2014 Location: Berkhamsted Posts: 113 ![]() ![]() ![]() |
Thanks, I will give this a go.
I only use it once a month...... Thanks Paul |
If you have acces to a wall outlet you could fit a small trickle charger? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
or solar charger
trouble is you got no alarm with battery off even bbus will be disabled |
"Or solar charger" ...
like I did ![]() ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
The normal solution is to have a small fused bypass feed which allows the alarm to remain fed (and central locking if you have it fitted) but which will not support anything greater power-wise and will certainly not permit the vehicle to be started. ONE LIFE, GET IT!
yes that's right but I think he wants to stop the battery running down , so disconnect all together to save battery
