Home > Maintenance & Modifications > Battery kill switch
666PXX
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Battery kill switch
I'm trying to fit a battery kill switch to my 2012 defender but when it is wired up and the switch is activated it kills every thing (this is good as that's what I want it to do,).
The problem I have is that the alarm then goes off! Shocked
Does anyone know how to get around this?
I'm fitting this because I very rarely use my defender.
Any help really appreciated Question
Post #346355 19th Jul 2014 8:53pm
munch90
turn battery switch off within 15 secs ( I think it's 15 maybe 10 ) of turning off ignition
I would say not really a good thing to keep turning it off
how rarely do you use it ?
Post #346367 19th Jul 2014 9:13pm
666PXX
Thanks, I will give this a go.
I only use it once a month......
Thanks
Paul
Post #346373 19th Jul 2014 9:24pm
VeeTee
Netherlands
If you have acces to a wall outlet you could fit a small trickle charger? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #346376 19th Jul 2014 9:27pm
munch90
or solar charger
trouble is you got no alarm with battery off even bbus will be disabled
Post #346377 19th Jul 2014 9:37pm
VeeTee
Netherlands
"Or solar charger" ...
like I did Wink
 Cheers, Vincent
MySite
Post #346385 19th Jul 2014 10:21pm
Litch
The normal solution is to have a small fused bypass feed which allows the alarm to remain fed (and central locking if you have it fitted) but which will not support anything greater power-wise and will certainly not permit the vehicle to be started. ONE LIFE, GET IT!
Post #346586 20th Jul 2014 7:58pm
munch90
yes that's right but I think he wants to stop the battery running down , so disconnect all together to save battery
Post #346594 20th Jul 2014 8:15pm
