Home > Td5 > coolant draining |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Anyone?
17th Jul 2014 8:21pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Would removing the small pipe at the front left of the radiator at the bottom do it? 2002 90 Td5 Station Wagon
17th Jul 2014 9:01pm |
What I have established is by removing the lower pipe to the radiator will drain 2/3rds of the coolant. Stupidly the engine block drain is apparently behind the alternator which means removing the ancillary belt and then alternator which is a pain. I was wondering if there is another option which works well?
18th Jul 2014 6:35pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
Are you trying to retain the coolant?
If not, the way I would do it, would be to do several plain water flushes to remove coolant in the block, then refill with proper coolant. |
18th Jul 2014 9:46pm |
