Home > Td5 > coolant draining
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
coolant draining
Planning to change coolant soon but have researched this and ended up with numerous versions of how to do this. Unfortunately, this has confused me so;
how do you drain the coolant without having to remove the alternator?
can someone post pics of each step (I know I might be asking alot Smile )
do I have to disconnect the thermostat?
Most of the posts I have read suggest I may only get 5-6 litres if I don't remove the alternator Sad
thanks Tommo
Post #345474 15th Jul 2014 8:55pm
Tommo
Anyone?
Post #345909 17th Jul 2014 8:21pm
grafty99
Would removing the small pipe at the front left of the radiator at the bottom do it? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #345915 17th Jul 2014 9:01pm
Tommo
What I have established is by removing the lower pipe to the radiator will drain 2/3rds of the coolant. Stupidly the engine block drain is apparently behind the alternator which means removing the ancillary belt and then alternator which is a pain. I was wondering if there is another option which works well?
Post #346123 18th Jul 2014 6:35pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Are you trying to retain the coolant?
If not, the way I would do it, would be to do several plain water flushes to remove coolant in the block, then refill with proper coolant.
Post #346168 18th Jul 2014 9:46pm
