![]() | Home > Maintenance & Modifications > My Electrical Adventure! LOTS of photos - Part 2 |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
What's rusting?
Bolts? You shouldn't be seeing much steel behind trim? |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Didn't know about that one.
Is this it? http://www.amazon.co.uk/Corrosion-Block-Pu...ion+grease I'll get some ordered ![]() |
that's the stuff but in grease form , you can get it in spray can
to be honest I think your hard pushed to beat waxoyl in some places , spray it in the crack and joints then use a hairdryer (something not too hot ) let the waxoyl melt in to joints and wipe excess off , when it cools it will seal the joint and as you wipe round your get a slight coating on and around what your spraying (as neat waxoyl get be a bit thick sprayed straight on something ) looks like the rust patches you got on the pic are from drilling swarf maybe after something was added , hoover out after drilling or spray with anti rust if swarf drops to wear to cant get at it Last edited by munch90 on 18th Jul 2014 9:39am. Edited 1 time in total |
Spray version ordered
![]() Thanks for the tip. Yep, hoovered everything we drilled. I will now be using the spray after hoovering on the rest of the install. Top advice. |
main of the swarf will be from the factory
make sure you have ordered the right stuff as some suppliers call normal acf-50 corrosion block acf is in pinkish cans corrosion block is in blue cans and not as easy to get |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
^ it aint easy to find!! still searching! My 109 thread
my youtube channel |
google search it
but one I found rust stop shop or there is a porsche spares place does it never used either of them , I got mine down in cornwall in a shop |
did you find it? |
This is what you're after I think :
http://www.amazon.co.uk/Corrosion-Block-Pu...B003DXMMP2 |
Riyo Member Since: 26 Jun 2014 Location: Aberdeen Posts: 89 ![]() ![]() ![]() |
top job there, i really like the sockets you have added for easy access to USB and the 12v in the back, i can see that coming in very handy for camping trips and the like, im wanting to do something very similar but am thinking of using a BEP VSR for the split charge, the only thing stopping me at the moment is getting my head around swapping the OEM 110ah for 2 Odyssey 1500's..i think they are 68ah each or something giving 136ah combined. it should be enough for my needs but im hoping i can have a brainwave and figure out a way of fitting more capacity without using luggage space for the batteries.
