Home > Maintenance & Modifications > My Electrical Adventure! LOTS of photos - Part 2
Jim_Bean
So after a year of ownership, much procrastination and worrying about invalidating warranties I (with MASSIVE help from taazzukcb) decided to get stuck in...
Installation photos below and photos of the Blue Sea split charge system in action Very Happy
Post #345917 17th Jul 2014 10:30pm
What are you fitting?
Post #345918 17th Jul 2014 10:36pm
Jim_Bean
*** UPDATE - Voltmeters installed - Split charge in action ***
Step 1 - Deep breath, throw warranty out of the window.
Step 2 - Out with all the OEM battery, jack and junk in the battery compartment
Step 3 - D44 Puma twin battery tray installed - Fits perfectly without any additional drilling required.
Step 4 - Optima Red top drops in as main started battery
Step 5 - Remove centre dash console - Just undo the two torx bolts and gently ease of of the 4 retaining clips. I marked all the connectors so i could remember where to refit them, but its surprisingly difficult to get it wrong as the loom is very well constructed so as you can't really put the wrong connector in the wrong block.
Step 6 - Cuppa tea
Step 7 - Install Blue Sea split charge controller. We found that it fits perfectly in the position the jack used to occupy. You can even use the rubber band (and 4 bolts) to hold it in place.
Step 8 - Drop in a Optima yellow top to act as the auxiliary battery. Fits great in the D44 twin tray.
Step 9 - Begin running wires down from inside the dash, exiting behind the heater, running under the mats and to the seat base.
Step 10 - Wire the batteries up via the Blue Sea solenoid - heat shrink, insulators and terminal covers recommended Smile
The big red 'blob' is the mega fuse that we have retained.
Step 11 - Wire the remote control for the batteries that will sit on the top of the dash. This allows you to manually connect or isolate the batteries or simply leave in "Auto" and let the Blue Sea gadget decide.
Step 12 - Ring 4x4 Overlander and order a Nakatenenga dash console to install switch and gauges. Excellent bit of kit that fits perfectly and looks a very close match to the OEM dash, if not better.
Step 13 - Another cuppa - stand back and admire vehicles.
Step 14 - Run some twin core wire from the battery box up through the B pillar, behind the headlining and into the rear box where the passenger side speaker is. Remove the cover and discover lots of rust on a 12 month old vehicle!
Step 15 - Cover everything in ACF 50 Smile
Good as new - no, better.
Step 16 - Take a 30mm hole cutter and and fit Blue Sea cigarette lighter socket that will connect to fuse box and be 'always on' for camping and expeditions.
Step 17 - Cut further 30mm hole in the glove box for 'always on' Blue Sea USB socket. Make sure to smile as you cut big hole in your massively expensive almost new vehicle that you saved for for 20 years!
Step 18 - Construct a bracket to hold a Blue Sea fuse box in a 'floating' posting above the two batteries. This give easy access to the fuses and loads of space for the wiring to run. Better than squashing it in the corner.
Step 19 - Wire up the sockets and install the fuses. Lots of insulators and heat shrink!
Step 20 - Run loads more wiring for roof rack lights, rear work lights, further sockets and a fridge.
This is my first attempt at anything like this in a long time. Massive thanks to taazzukcb for all the help and guidance. The Blue Sea stuff is top quality as is the Nakatanenga kit.
The split charge is working a treat as are the sockets. Just need to get the voltmeters and lights wired next.
**** Update ****
Installation of Voltmeters using relays and taking the ignition signal from the purple/black wire on the factory cigarette lighter loom. Went with "Smiths" voltmeters from Demon Tweeks for that series Land Rover connection Smile
New Smiths voltmeters fitted (carling switches in readiness for roof rack lights and rear work lights):
Relays ensure the voltmeters only actuate when the ignition is on -
Right hand meters shows red Optima 'starter' battery level - Left hand meter shows yellow Optima 'auxiliary' battery. You can see the split charge system working well as you start the vehicle.
Photo 1 - Ignition off - Batteries isolated.
Photo 2 - Engine on - there is a 30 second delay before the 'intelligent' Blue Sea solenoid detects the incoming charge from the alternator.
Photo 3 - Charge detected and the solenoid joins the batteries together, red LED lights the 'auto' setting on the switch, system automatically 'splits' the incoming charge across the two batteries:
Hope this helps you guys with your own builds Very Happy
Thanks for all the encouragement Thumbs Up
Lights next week..
Post #345927 17th Jul 2014 11:26pm
Pickles
Jim, you are oviously very competent,..you have some great skills.
Congratulations on some very nice work.
Pickles.
Post #345932 17th Jul 2014 11:39pm
Jim_Bean
Its been great fun and not quite as terrifying as I thought it might be!
Just needed the push to get going from Bow down taazzukcb
Understanding and wiring the relays for all the auxiliary lighting is the next step. Again, the best way to learn is to just go for it i guess Very Happy
Post #345935 17th Jul 2014 11:57pm
Excellent work there, some of the best work I've seen on here.
Thumbs Up
Post #345936 17th Jul 2014 11:58pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Incredible attention to detail Thumbs Up , you could perhaps offer your skills to other defender owners, if the price is right
Post #345937 18th Jul 2014 12:14am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
That's a quality job you've done there. I particularly like the novel use of a pair of shelving brackets to hold up the fuse board!
Thumbs Up
Post #345980 18th Jul 2014 9:20am
As a 'newbie' I think you've done amazingly well Bow down
A tip for next time, it is worth getting a collection of different coloured rolls of cable (Beales are often doing great deals on weird colours) as it will make fault finding at a later date or adding to circuits a lot easier.
Sorry Embarassed I don't like the shelf brackets, very functional but in my humble opinion spoil the look of a quality install
Post #345983 18th Jul 2014 10:13am
^^^ That was the only bits that I thought let it down. Looked naff Whistle
Other than that, excellent neat job. I can't stand untidy wiring.
Post #345984 18th Jul 2014 10:13am
Another tip, learnt the hard way Rolling Eyes , remove rings, bracelets etc when working with electrics ....
Post #345985 18th Jul 2014 10:15am
Jim_Bean
I guess the brackets are more 'function over form'. They do offer a very study base for less than £2 Smile
If I had better tools I guess I could have fabricated a more professional looking mount but for the money they are painted and hopefully will stand up to time well.
At least you can't see them!
Post #345987 18th Jul 2014 10:17am
munch90
deleted
Post #345988 18th Jul 2014 10:20am
Jim_Bean
One thing that has been surprising is the amount of surface rust on almost all the surfaces hidden away behind trim panels, consoles and floor mats. Almost everything has a least some corrosion or rust.
I need to make a 'sheep dip' of ACF50 and sit the Landy in it for a few hours. I just don't get why Land Rover can't be bothered to add even a little bit of protection.
On the plus side almost all the trim is easy to remove and you can get a good coating of your favourite anti-corrosion spray all over.
Post #345989 18th Jul 2014 10:21am
munch90
go one better and use corrosion block , made by the same people
seems to me that acf50 has to be applied more often and if your doing behind panels you need to take them out to keep spraying it
Post #345990 18th Jul 2014 10:25am
