Home > Maintenance & Modifications > Additional air intake - suggestions please
ZeDefender
After recently fitting a new turbo and intercooler, I'm thinking of refitting my RAI.
However, since I took it off in the first place because it was restricting airflow, I'm now thinking of adding an extra air intake forward of the wheel arch. It should be simple as a hole at that position is in exactly the right place to run a flexible tube to the front/bottom of the airbox. It would barely be a foot long Thumbs Up
So, can anyone suggest some ideas for fittings for the tube to go into the airbox at one end and the wing at the other? Obviously I want it to look as OEM from the outside as possible Smile
Cheers for ideas
Matt Tell someone you love them today because life is short.
Post #344886 13th Jul 2014 2:44pm
Cheshire110
Surely that defeats the object of a RAI? Cheers, David
Post #344888 13th Jul 2014 2:57pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
top of the wing where the blank for the heater intake is, unless yours is a left hooker?
Post #344890 13th Jul 2014 3:08pm
ZeDefender
LHD Rolling Eyes
David - would be but I'll block off the additional intake for dusty/wet use Thumbs Up Tell someone you love them today because life is short.
Post #344900 13th Jul 2014 3:53pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Would this do it? .. http://nakatanenga-tours.de/shop/article_O...DOAITD4%26
Was thinking of one of these but a bit pricey Shocked 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #344903 13th Jul 2014 3:59pm
ZeDefender
Shocked
Er... I was hoping DIMyself wouldn't be so painful Laughing
I've actually found some 80mm tubing with a lip at one end (will go to the wing) but I want a nice airtight seal at the airbox end. I also need some kind of external cover (one I can take off to block it). The raised wing top covers on eBay are the right shape but I can only find cheapo ones out of crap plastic... Tell someone you love them today because life is short.
Post #344914 13th Jul 2014 4:16pm
ickle
I was thinking along the same lines, but merely putting an access hole through the bottom of the plastic jobby, in line with the wing vent and fitting something like this
http://content.yudu.com/Library/A1w86o/201..._Tanks.htm
Page 20, item 2
Should blend with the plastic of the mantec rai and be 100% sealable should the need arise?
Keith
Post #344921 13th Jul 2014 4:34pm
Cheshire110
just realised how snotty that sounded, sorry!
wing top is a good idea. you could team it up with a snow cowl for a quality finish Cheers, David
Post #344923 13th Jul 2014 4:38pm
borderterrier
http://www.defender2.net/forum/topic25864-30.html
Still working on upper wing intake and snow cowl
Post #344927 13th Jul 2014 4:47pm
ZeDefender
Okay - after an age of searching I've bought a couple of these in 86mm and 114mm:
http://www.visaton.de/de/chassis_zubehoer/zubehoer/gitter8es.html
I may need to change the mesh to get better air flow but hopefully they'll help the inlet look tidy Smile
The Ramair hose is 80mm and is the biggest that will fit neatly into the airbox at the bottom - it has a lip to keep it in the wing:
http://ramair-filters.co.uk/ducting-automo...d-cap.html
- still haven't figured out how to seal it into the airbox though. Perhaps if I cut the hole small enough I can wedge it in between the ribs.
May take a while as the hose is coming from your end (hmmm - does that sound bad?)
Post #345049 14th Jul 2014 6:47am
K9F
Easiest way would be to get a fabricator to source a length of 80mm stainless steel O/D pipe and get him to put a flange on it. You could then gasket seal and bolt the flange to the airbox.
Just a question but how are you going to fair TUV time with this?
Alternatively find a decent plumbers as 80mm is a common size used in domestic plumbing and see what they may have.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #345075 14th Jul 2014 9:59am
mikeh501
dual snorkels would look awesome too.
Post #345105 14th Jul 2014 12:32pm
ZeDefender
I wish I could find a fabricator here that would do it (even better for a sensible price) but you remember the trouble I had just trying to get my bike forks welded...
The TÜV (for once) shouldn't have a problem with it - there's only going to be a "speaker cover" on the wing and cutting a hole in the airbox isn't a crime. According to Pete, with the factory map back on, the 110 will be back to a dreary 122PS again Wink Tell someone you love them today because life is short.
Post #345106 14th Jul 2014 12:42pm
Matzker air intake kit
Post #345116 14th Jul 2014 1:32pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
On my previous Discovery 2 td5,i noticed some breathing "issues" after the snorkel fitment,which got worse after stage 2 remapping,so i made this ...
and whenever needed i screwed the caps on-it was made out of oil bottles' necks,not feasible with puma plumping Evil or Very Mad
On puma i decided to get rid from the snorkel..till i make my own 100 mm version Whistle
The military style versions exiting the top of the wing seems better idea but being a LHD puma is a little more complicated Sad
Post #345133 14th Jul 2014 2:34pm
