Home > Maintenance & Modifications > Welding the turbo? |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
And all these brings this http://www.defender2.net/forum/topic26212.html in the discussion
As BAS mentioned even standard pumas run high egt's. After readind tons of articles all over the web,i am convinced that when tuned(sometimes even in standard form) you'll have to drive by the egt meter. I lowered the egt alarm to 650 celcious,i rarely hit it now and exaust seems ok after 3500 klms,the sad thing is that the other day i drove a mates untuned puma,no egt meters etc. On the same long ascent i got it to speed limiter and speed started to drop a little. I did the same with mine,got it to same klms faster but i had to back off the throttle(and drop speed) cause the egt's went high Next time we'll test both pumas at the same time (gents place your bets!) but i am afraid that the stock puma will finish first.. No conclusion |
10th Jul 2014 12:01pm |
