![]() | Home > Technical > Horn sounds like it has a sock in it. |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
I've never really heard of one drying out. I dont think a new 12v horn will cost you too much.
But as mentioned, before you go purchasing new, make sure you have full battery voltage to the horn from the plug. |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
mine regularly gets filled with mud. a quick blast with the jet wash solves those issues
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Take a broken horn as a reason to upgrade
![]() Best |
Buccaneer Member Since: 11 May 2014 Location: London/Kabul Posts: 148 ![]() ![]() ![]() |
Horn was
![]() 1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
So did the horn sound change before or after the Trucklites were installed. If after, seeing as the horns are behind headlights, then definitely check connections.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
