Home > Puma (Tdci) > Speedo perspex face Puma County 90 |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
Have a look out for a speedo binnacle from a Discovery 3 - I'm fairly confident that the plastic face is the same (although the clocks are different...) My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
25th Jun 2014 2:05pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
The cluster was also used in a Freelander.
See here for a replacement: eBay Item No. 221292076704 http://defender90xs.blogspot.co.uk/ |
25th Jun 2014 5:43pm |
OleDave Member Since: 19 Oct 2013 Location: CARDIFF Posts: 175 |
Thank you both for replying, SiWhite your a star as I have just looked at ebay and it seems the same as the lens in my lovely girl!
Will order one tomorrow as its doing my head in looking at the crack propagating every time I dirve it. Many Thanks to both of you for your time and trouble. This forum is fab. Regards ole dave |
25th Jun 2014 5:59pm |
Spartan Member Since: 24 May 2014 Location: Internet Posts: 8 |
I just replaced my instrument cluster faceplate from a KPH to MPH last night. Removing the needles were a little challenging. You have to twist/spin the needle/pointers to loosen them from the pivots. I was able to put it all back together and all is working well.
25th Jun 2014 9:18pm |
surf110 Member Since: 14 Jan 2008 Location: Rio de Janeiro Posts: 43 |
Spartan. Can you elaborate on this swap. I also need to change from km per hour to mile per hour. I bought a whole new instrument cluster but I couldn't get it programmed. Did you buy just the face or a whole cluster and just used the face?
28th Jun 2014 1:45am |
28th Jun 2014 5:53am |
long nose pliers helps ! |
28th Jun 2014 6:14am |
I had a MPH complete cluster and removed the face from it. I used the MPH face on the KPH cluster. I did not use any tools because I was afraid to damage the pointers. I took the cluster apart to the board level then removed the face and did the swap. The pointers did not want to come off without first twisting them. Make sure you remember where you started before twisting the pointers. ( otherwise the accuracy of the gauge will be off). |
28th Jun 2014 9:04pm |
Do you guys think a face from a Disco 3 instrument cluster work work?
29th Jun 2014 5:00am |
I will have to replace my glass at sometime . it started cracking within a couple of months from new .
cracks are about 30mm up the plastic glass from each bottom corner now |
29th Jun 2014 8:17am |
DavinaTree Member Since: 23 Jun 2019 Location: East Sussex Posts: 14 |
Hi - I’m looking to replace just the Perspex fascia on the instrument console - as others above - but I can’t seem to find the Perspex sold on its own or the instrument cluster for reasonable price - just want the Perspex fascia - can anyone help? Puma 2.4 defender. Pic for attention
23rd Jun 2019 2:36pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Have you tried eBay? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
23rd Jun 2019 3:41pm |
There are plenty of expensive instrument consoles but can’t find just the front Perspex fascia
23rd Jun 2019 5:38pm |
Maybe worth taking a punt buying one taking out the Perspex and then reselling what’s left 2015 HT XS 90
23rd Jun 2019 7:28pm |
