Home > Puma (Tdci) > Heater Controls
Phil_D
Heater Controls
My '08 DCPU has developed an annoying fault with the heater controls in that the slider for recirculating the cabin air wan't move and the rotary control for airflow direction is stuck. I'm planning to take out the dashboard centre panel but I'm not familiar with the heating and ventilation system and wondered if anyone can suggest what to look for?
Thanks,
Phil.
Post #340654 25th Jun 2014 7:02am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Phil
Have a look here Daniele kindly hosts Puma workshop manuals, it should have the information you need
https://onedrive.live.com/?cid=4bc2d89c85c...C171%21552
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #340669 25th Jun 2014 8:11am
Dieselhead
My mates did this. I just took off the front of the panel & had a fiddle.
I think it was just 2 things trying to select at the same time Confused
Any how put it back & alls been fine ever since Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #340677 25th Jun 2014 8:36am
Phil_D
John, thanks for the link, I found the relevant section. The diagrams are useful and I learned some new terms ('blend door control cables', marvellous!).
Chris, yes, looking at the diagrams I'm guessing it's simply that things have got tangled. Very helpful to see what's behind the panel before removing it!
Phil.
Post #340683 25th Jun 2014 9:16am
bear100
I had the same, can't quite remember but I am sure it was the force of the fan being on holding it in position?
Have a fiddle in a few settings first
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #340772 25th Jun 2014 5:35pm
Phil_D
Thanks for the suggestion but I don't think any amount of fiddling will free it - panel off, I'm afraid.
Phil.
Post #340784 25th Jun 2014 6:32pm
Quite often problems with the sliders are down to the plastic melting and deforming due to the heat from the bulbs illuminating the controls, a very common problem.
Be very careful with the heater control unit, it is only available as an assembly and is STAGGERINGLY expensive!
Post #340796 25th Jun 2014 7:21pm
Phil_D
Thanks, I'll be careful!
Phil.
Post #340920 26th Jun 2014 9:34am
