Home > Technical > Diff/Peformance Odyssey PC1700 and Metal Jacket version
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
Looking to replace my 9 year old battery and don't want/need a dual battery setup. My defender 90 only gets used at weekends and looking for a very good reliable battery that should last another 9 years.
The standard Odyssey PC1700 is circa £232 and Metal Jacket version £272.
My question is for the extra £40 am I going to get any extra performance and under what circumstances would you need the metal Jacket version.
Also anyone know/recommend cheaper price?
Cheers, Andy Defender Td5 XS90
Post #339593 20th Jun 2014 10:39pm
jimbob7
OEM batteries seem to last for 8-9 years (£170), or you can get a 900 amp Yuasa battery with 5 year guarantee for £130 or less.Cost-co sell Bosch batteries pretty cheap,unless your after extra performance just another (cheaper) option Thumbs Up .
http://www.halfords.com/webapp/wcs/stores/...yId_165762 Pov.spec,ftw. 2006, 110,TD5.
Post #339663 21st Jun 2014 11:09am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
+1 for Costco. I have a S5 Bosch battery in my Defender for a few years now, it's a direct replacement for the original OEM. Battery. Great performance and it was £99 when I bought it 3/4 years ago. Also comes with 5 year warranty. I thinks the specs (CCA & AH) are same or better than OEM.
Simon
Post #339733 21st Jun 2014 9:54pm
landy andy
Odyssey batteries are great and would be my choice, it is a good quality that won't suffer should it be run down, unlike standard type batteries.
Brought mine from Devon 4x4 who were by far the cheapest I could find and they did free postage.
Andy
Post #339782 22nd Jun 2014 10:11am
couplands
^^^good point, I damaged a previous battery after a current drain problem left the battery flat for a few weeks.
If you're still looking for Odyssey, then these guys seem to have a fair price too...
http://www.griffinbatterycentres.co.uk/com...ery/14-162
cheers
simon
Post #339787 22nd Jun 2014 10:31am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
I have used Odyssey PC1700 and although I like them they do not seem to last long. My last pair died after 4 years, which, I am told is not bad for Odyssey ! Now running Optima which have not lasted well, 2 years old and starting to loose charge.
Bosche / Varta or OEM seem to be the way to go. Unfortunately they won't fit in the space for my twin set up ! 2007 TD5 90 Hard Top
Post #339861 22nd Jun 2014 5:13pm
walfy
Andy
I've found cheaper by about £25 a battery so if you know where to look there are other suppliers. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #339868 22nd Jun 2014 5:40pm
couplands
Not good to hear that, at £200-250 per battery..!
I have seen a twin battery tray that will take two S5 Bosch batteries (the OEM size), so may consider that. As I already have 1 x S5 it would be a saving as another is only £100-ish. The battery tray is a bit more that the Devon type @£125.
I was hoping a deep discharge capable battery like the Odyssey would last longer for running accessories, but if that isn't the case it doesn't make much sense to use them.
cheers
simon
Post #339947 22nd Jun 2014 8:56pm
Force64
Thanks all.
Don't need a dual charge system as no fridge or winch, so one large battery is fine. The Odyssey PC1700 is about the same size as the existing LR original. The cheapest I can find it is on Amazon at £218.25.
I will however be contacting Tim and Brendan to see what they can do on pricing as I've had bits from them both recently and their service is great.
Post #339953 22nd Jun 2014 9:04pm
Cupboard
Bear in mind that whilst the Odyssey may well be a "deep cycle" it's got a substantially lower Ah rating than the stock battery.
In a lot of circumstances this won't make a jot of difference as the CCA/Ah ratio is higher but it is worth noting.
Post #339978 22nd Jun 2014 11:50pm
couplands
Given all of the above comments, what is the real world advantages of fitting an Odyssey battery in place of the Bosch S5 (for example)...?
Simon
Post #340003 23rd Jun 2014 8:11am
Landlord
They can take a licking but keeps on ticking Very Happy
Basically a more forgiving battery if abused. Will also stand being tipped over, heavily discharged and high amperage discharge with a winch etc. Thats why they seem to be popular in winch challenges and extreme events.
However if I can find two batteries that will fit my tray ill try something different next time. 2007 TD5 90 Hard Top
Post #340012 23rd Jun 2014 8:35am
jimbob7
If your worried about weekly discharge,is a solar powered, battery trickle charger not an option? FWIW, I only use mine once or twice a week and touch wood I've not had any battery issues,(that was a kiss of death I'm sure Rolling Eyes ). Pov.spec,ftw. 2006, 110,TD5.
Post #340055 23rd Jun 2014 10:49am
Force64
Well then. Decision made, order placed and delivery due tomorrow.
Post #340775 25th Jun 2014 5:43pm
SteveDurham
United Kingdom 2006 Defender 90 Td5 CSW Zambezi Silver
I’ve used Yuasa and always found them to be very good..
Post #1018488 16th Dec 2023 7:14am
