Home > Maintenance & Modifications > Axle oil contaminated with CV joint grease
Page 2 of 3 <123>
AlanH
Australia
I didn't sniff it really Caterham but to me was just that normal horrible diff oil stink. Something like a seal has obviously worn but others say this seems to be normal. Crying or Very sad The mechanic (very experienced with LRs) who did the 80K service didn't really seem to think it was prob and thought someone may have used an additive. Now it's the same now I've checked it I'm wondering what may have happened in there.
AlanH.
Post #339384 20th Jun 2014 9:07am
K9F
Caterham wrote:
I'm not convinced it's right and suspect something is wearing out - would be good to get some feedback to confirm if it is / isn't normal?
Here we go again! Whistle
Mark prepare to have your thread hijacked. You'll not need to do anything but monitor this one. Caterham's relentless pusuit for 'non faults' and his doggedness to spend time and money on a cure for them is well documented and quite amusing.
Rolling with laughter Bow down Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #339388 20th Jun 2014 9:11am
Caterham
come on Mal - answer the question.
is yours as per mine and AlanH - tell us both all is ok? Very Happy
Post #339393 20th Jun 2014 9:38am
K9F
Caterham,
I really don't care and am not about to go and have a look. I had similar issues on each of my three Discoverys where the oil was leaking from the centre of my front wheels an indication the seals had gone. Lubrication is lubrication, oil used to go in both but they then decided that one shot grease in one and oil in the other was the better option. I was advised by a very reliable source it didn't matter so I left well alone and all was fine.
This is quite common.....
bga86 wrote:
Every defender on the road has this issue, it won't cause any harm !
AlanH wrote:
This is the 3rd time it's been like this,
MK wrote:
I do not think it is a big issue though.
It is not a big issue....All will be fine leave well alone!
Read on for more info.....
http://www.defender2.net/forum/topic26598....swivel+oil
http://www.defender2.net/forum/topic23985....swivel+oil
http://www.defender2.net/forum/topic23675....swivel+oil
rossy wrote:
Yes, usually oil migrates towars the swivels. Back and forth. I would not worry too much about it.
Above quote taken from this thread.....
http://www.defender2.net/forum/topic12141....swivel+oil
'Swivel Oil' in the search throws up 48 threads. The information you seek is already here on the forum......look for it. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #339417 20th Jun 2014 11:30am
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
I changed oil in both front and rear diff a month ago. Never done it before since I had the vehicle for just about a year. The oil in the rear diff was in a nice condition but the front was totally black.
I just filled up with new oil and topped up with swivel grease and will run it for another year and then probably only change oil in front diff. Unless some other suggestions comes up in this thread Rolling Eyes
/Hans
Post #339492 20th Jun 2014 5:24pm
Caterham
Phew.... (mal - Very Happy )
So it seems the front is typically coming out black, but why - is it to do with the steering and as such the diff does more work (having thought about it does it actually do anymore than the rear)?
Post #339508 20th Jun 2014 6:13pm
HansT
After reading the other treads on this subject I am convinced that it is swivel grease contamination. But as long the diff is ok with some grease in the oil I am happy with it as well. But I think that I will change oil in the front diff once a year.
/Hans
Post #339518 20th Jun 2014 6:31pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
That's OK, I'm finished with the thread anyway. Very Happy I rebuilt the hubs and the oil is still fairly clean after 2 months and about 1100 miles.
http://defender90xs.blogspot.co.uk/2014/04...ement.html http://defender90xs.blogspot.co.uk/
Post #339524 20th Jun 2014 6:59pm
mark_d
Post #339526 20th Jun 2014 7:00pm
Caterham
Embarassed
I've just drained the front again after c1000 miles and the oil was far from clear?
This together with the rumbling I get when slowing down makes me think something isn't as it should be?
Post #339535 20th Jun 2014 7:19pm
jst
on one of mine i removed the seals at the end of the axles tubes to allow the two to meet, quite a few do this as a matter of course.
i would worry about it. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #339540 20th Jun 2014 7:33pm
Caterham
Brill so that suggests I can use the diff oil for the hubs.
Will do a search to see how much oil goes in the hubs (presumably they're filled via the sump plugs on the top?).
Post #339550 20th Jun 2014 8:06pm
munch90
I was always told oil in front hubs is better than grease , and I believe that it is
the one shot grease tubes were only done to save changing the hub seals , a bodge job really
I was told if hub will hold oil then use oil !
Post #339570 20th Jun 2014 8:59pm
AlanH
Australia
I did have a slight oil leak from the swivel seals but the stealer fixed that and it's now OK. This is our third Deafener (for some yet be found reason Confused ) but it's the first to do this. Ford cost cutting and meddling perhaps?
AlanH.
Post #339600 20th Jun 2014 11:25pm
munch90
don't forget if the hubs have grease already in them ,you need to strip them down and clean all the grease out IF you only want oil in them
or add a bit of oil to the grease not full amount
if your worried about wear in axle , as you drain the oil run it over a magnet as it drains to check for metal or fit a magnetic plug
Post #339629 21st Jun 2014 7:41am
Page 2 of 3 <123>
