![]() | Home > Puma (Tdci) > 600 IS possible |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
very good economy
![]() not only do I try and save fuel (incase you hadn't noticed) but I also try to reduce brake pad wear....when approaching islands at the end of a fast / dual carriage way for example I use engine braking and sometimes turn the a/c on to increase engine braking ![]() |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 ![]() ![]() ![]() |
yes I'm pleased with the mpg I'm getting, as I say it took a while to get my technique, just sticking it in the highest gear isn't the way to go, I rarely use 6th for instance unless I'm doing over 50 I use the torque app on a cheap android tablet that lives in the truck, but over 30 purely urban is pretty pleasing and yes engine braking, I never dip the clutch and coast because the engine then ticks over which uses fuel, albeit a small amount, just taking your foot off the pedal stops the fuel flow and you use none, I have a re map which I reckon helps, it increases torque mine is "farmer spec" so I don't have air con
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
My speedo is bang on with stock wheels. |
someone somewhere asked about my mpg while towing so here's a few stats;
b'ham to Eash coast then towards Lincoln plus pottering around East coast - 346 miles (c 246 with heavy caravan). took 61 ltrs to refill - so approx. 25.8 mpg. |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Mine did about 400 miles to a tank... Going to wales and back home!
Very good i'd say... ![]() Air con on most of the way. Fabio |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Whilst admiring the fuel efficiency and endeavours therein.
I`am a little bit worried about people slip streaming trucks (if I read this right ). Having being rear ended twice by tail gaters it`s not much fun. On one occasion I was driving a 7.5 tonne truck, had to pull up quick due to a child slipping from her mothers hand thank fully I missed her ( she was 4 foot away from my front number plate). Then the bang a car went right under my rear, he was removed on a spinal board...... It may be all well and good saving a few quid but if something were to fall of said truck or trailer you may not be able to react in time. And the stone chips. The idea of engine braking sounds short sighed as we all know the weakness of the clutch springs, not mention the rest of the gearbox is a bit iffy, turning the air con on will do little as the compressor is cycled on and off under normal conditions. The condenser fan will use little power as it`s already turning from the forced air flow as we know it takes a lot less to run a motor than to start it. All this low rpm engine use may cause more long term harm than good, even if the high pressure pump holds together by running low on diesel I would not be happy pulling fuel from the base of my tank / filter. Excuse the spelling I`am better with spanners and wires. |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
This was my understanding of modern diesel engines and I drove according to help mpg. I fitted an ultragauge recently, and whilst it isn't calibrated yet, it does show relative changes in mpg. What confuses me is that the instantaneous mpg shoots up when I press the clutch pedal and the revs drop. It seems that it is more efficient to coast Does anyone know how the ultragauge calculates fuel economy? http://defender90xs.blogspot.co.uk/ |
Not sure the scan gauge works but not very well from what you have said.......
Can't say 100% this is the same with all modern diesel engines but the golf we have - you can clearly hear the pump / injectors when coasting but not when decelerating in gear if that count for anything? Quick update date....at 323 miles and half tank left ![]() ![]() Click image to enlarge |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
So what mpg would you get if you dropped the spinnaker and took the mast down?
![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
Not sure, but with it up about 38
![]() Will hopefully have enough pennies for a bigger intercooler, remap and decat which I hope may improve things further? I need to drop my mate a note shortly too as I think he was struggling to make up in his c220 today ![]() |
wow.....how about that for consistency.
check this photo with the one above ![]() ![]() Click image to enlarge |
Wow now that is finally impressive, over 21,000 miles without using any fuel whatsoever with the handbrake on! That'll be why the temperature is up. Think you've an issue with the trip meter though, best go investigate and start a thread forthwith? ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
![]() with a thread like that you're clearly in good form Mal (at least I trust you are?). ![]() things are going really well at the moment (although saying this is probably going to scupper things) so lets just see how long it lasts ![]() ![]() |
