![]() | Home > Tdi > Tweeking of the Injection Pump |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Had a look today and noticed the tamper proof plug was missing so assume its been tweaked at some point anyway this is what I found.
as soon as I removed the top i could see right away that the diaphragm had been marked with a mark pointing at 3 o clock ( front of engine ) and a mark pointing at 6 o clock ( pointing to o/s/f wheel ) and the top of the smoke screw was level with the lock nut. so as i wasn't sure i decided to leave it a loan and ask on here if everything i have found says its been tweaked or put back to std what do you think ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
when I done my 200tdi I didn't touch the top of the pump at all , there was a adjuster screw on the back of the pump by the injector pipes
I adjusted mine because I had big intercooler and had a turbo build to my spec |
Have decided to fit the new correct exhaust first and then have a mess with the injection pump later
Son got the tdi exhaust yesterday and had ago at fitting it but hit a problem so i am going round later when i get up as i work till 10pm most nights and see what the problem is so will let you know tonight / early morning what it was or is
Sorry for not posting back on this, son had put the clamp that fits round the front pipe to manifold in the wrong position meaning it was clamping wrong if you know what I mean and not gripping the front pipe causing all the exhaust to move slightly but all sorted now
![]() going to have a go at tweaking the pump later after making a few adjustments to the exhaust ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
After i did the exhaust i tweaked the pump and WOW what a difference it has totally transformed my 90
![]() ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
My eccentric cam thing has been adjusted about an 8th of a turn just enough not smoke but enough to liven the off boost and honestly that's all it needed to make it a delight to drive. It effectively smooths the transition to on boost making it feel very linear much like mothers Mercedes. Rhubarb and custard let fly with their secret weapon.
what bit you adjust on the pump ?
When i removed the top i could see that the diaphragm was marked up at 3 oclock and 6 oclock so think its been messed with before but i also noticed as the tamper proof cap was missing aswell that the smoke screw and lock nut were level with each other and notice with pic's of other's where they had been tweaked that there was a bit of thread showing on the smoke screw so i took note of where the smoke screw and lock nut was and backed the smoke screw off 3/4 of a turn and it goes like stink with a very slight trace of smoke on idle and when you rev it it smokes slightly but i am very happy with it
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) Last edited by cornish rattler on 17th Jun 2014 8:57am. Edited 1 time in total |
I didn't do mine so all I know is that the eccentric cam was moved. Rhubarb and custard let fly with their secret weapon.
deleted
