![]() | Home > Puma (Tdci) > battery junction box missing fuse? |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Guess you dont have ABS fitted as its an extra
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 ![]() ![]() |
Standard on the xs?
I've got an abs check light (and traction control) on the dash when I turn on the ignition. |
Permanent or do they all extinguish once you reach above 5mph? If you go through life with your head in the sand....all people will see is an ar5e!!
They turn off at the same time the glow plug light goes off
I have a 08XS and I popped out to have a look and my fuse slots are all occupied including the blade slots where you've another missing. If yours is still under warranty pop along to your dealer and ask or pop a couple of fuses in and see what happens.
ABS light should remain illuminated until you exceed 5mph. ![]() Treat every day as if it is your last....one day you will be right!! |
Thanks, much appreciated!
Spoke to dealer today who said "it's just american spec that have this populated" As you can't sell a puma in the US that doesn't sound right... However I know that products change continously in production so this may be a difference between 08 and 11 my? |
Ive an 09 XS and my fuses are inplace wonder why theyve been removed
I thought it was part of the xs pack for MY11. Which included the following over the county spec:
Anti-lock Braking System/Electronic Traction Control Side runners Rear door stowage net (Station Wagons and Utility Wagons only) Air conditioning Ripstop/leather seats Leather steering wheel Leather covered gear selector and range selector 7 Seats - additional 3rd row (110 Station Wagon only) Cubby box in vinyl trim Single slot CD, radio including MP3/AUX & dash mounted tweeters Heated front screen Heated front seats Metallic paint Can the OP confirm he has all the above? |
Hi
Yes, got all of these, plus lr supplied winch bumper, warn winch, steering guard, towbar, mats, chequer plate etc. Looks quite cool. It's a land rover assured vehicle so should be straight. |
In manual that's shown as a yellow 20 amp fuse but "not used", so maybe been taken as a spare elsewhere? Looking again, you appear to also be missing the anti-lock brake system (ABS) pump relay, which should be to the left of the bank of 3 shown above the fuses. |
You're right, no relay in pos 1 far left.
Just so I know I'm not going mad, this is the hcu for abs/traction control, right? ![]() Click image to enlarge This looks like a newer model than the one in the manual. The vehicle is a July 2011 build so quite late maybe this explains differences? |
ABS Modulator.....
Puma 2.4 up to MY2010, ABS is WABCO (same as td5) Puma 2.4 MY2011, ABS is BOSCH Puma 2.2 MY2012 and newer, ABS is BOSCH
Does yours do this?......... ABS light should remain illuminated until you exceed 5mph. If not it may be there is an issue and to mask it the fuse has been pulled. Does the ABS and traction control actually work? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Do the tests, as K9F suggests it does look a little suspicious, especially with the
Tested. Result, one muddy landrover. Abs works, traction control works - lights up on dash (last bit was quite difficult as continental tyres are quite good).
Thanks for all replies, very much appreciated. |
