Home > Puma (Tdci) > battery junction box missing fuse?
Hal
Newbie question. I've just bought an 11my 2.4 110xs sw as 1:i've wanted a land rover for 27 years, and 2: it's just criminal that they're going out of production.
I've spent a few weeks with it and it's just brilliant. Taking it apart to learn more about it though I came across what looks like a missing fuse assembly - see missing assembly in the horizontal row of fuse on the left of the pic. This is the battery junction box under the driver's seat
Internet docs say this should be a 30A ABS return pump fuse.
Anyone got an 11my 110xs sw that they can compare with? Is my fuse assembly missing?
Thanks
Post #338482 16th Jun 2014 4:23pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Guess you dont have ABS fitted as its an extra
Post #338483 16th Jun 2014 4:34pm
Hal
Standard on the xs?
I've got an abs check light (and traction control) on the dash when I turn on the ignition.
Post #338484 16th Jun 2014 4:40pm
K9F
Permanent or do they all extinguish once you reach above 5mph? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #338485 16th Jun 2014 4:41pm
Hal
They turn off at the same time the glow plug light goes off
Post #338486 16th Jun 2014 4:44pm
K9F
I have a 08XS and I popped out to have a look and my fuse slots are all occupied including the blade slots where you've another missing. If yours is still under warranty pop along to your dealer and ask or pop a couple of fuses in and see what happens.
ABS light should remain illuminated until you exceed 5mph.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #338487 16th Jun 2014 4:48pm
Hal
Thanks, much appreciated!
Spoke to dealer today who said "it's just american spec that have this populated"
As you can't sell a puma in the US that doesn't sound right... However I know that products change continously in production so this may be a difference between 08 and 11 my?
Post #338489 16th Jun 2014 4:54pm
110 John
Ive an 09 XS and my fuses are inplace wonder why theyve been removed
Post #338490 16th Jun 2014 4:55pm
I thought it was part of the xs pack for MY11. Which included the following over the county spec:
Anti-lock Braking System/Electronic
Traction Control
Side runners
Rear door stowage net (Station Wagons
and Utility Wagons only)
Air conditioning
Ripstop/leather seats
Leather steering wheel
Leather covered gear selector
and range selector
7 Seats - additional 3rd row
(110 Station Wagon only)
Cubby box in vinyl trim
Single slot CD, radio including
MP3/AUX & dash mounted tweeters
Heated front screen
Heated front seats
Metallic paint
Can the OP confirm he has all the above?
Post #338491 16th Jun 2014 5:01pm
Hal
Hi
Yes, got all of these, plus lr supplied winch bumper, warn winch, steering guard, towbar, mats, chequer plate etc. Looks quite cool.
It's a land rover assured vehicle so should be straight.
Post #338493 16th Jun 2014 5:08pm
In manual that's shown as a yellow 20 amp fuse but "not used", so maybe been taken as a spare elsewhere?
Looking again, you appear to also be missing the anti-lock brake system (ABS) pump relay, which should be to the left of the bank of 3 shown above the fuses.
Post #338495 16th Jun 2014 5:17pm
Hal
You're right, no relay in pos 1 far left.
Just so I know I'm not going mad, this is the hcu for abs/traction control, right?
This looks like a newer model than the one in the manual. The vehicle is a July 2011 build so quite late maybe this explains differences?
Post #338500 16th Jun 2014 5:54pm
K9F
ABS Modulator.....
Puma 2.4 up to MY2010, ABS is WABCO (same as td5)
Puma 2.4 MY2011, ABS is BOSCH
Puma 2.2 MY2012 and newer, ABS is BOSCH
Laurie wrote:
To test it, park with one side on wet grass and the other side on tarmac.
Accelerate quickly.
You'll soon see if it's working or not.
Does yours do this?.........
ABS light should remain illuminated until you exceed 5mph. If not it may be there is an issue and to mask it the fuse has been pulled. Does the ABS and traction control actually work? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #338504 16th Jun 2014 6:12pm
Do the tests, as K9F suggests it does look a little suspicious, especially with the Censored answer given by dealer, which sounds like it's more designed to get rid of you quickly then actually reassure you Evil or Very Mad
Post #338526 16th Jun 2014 6:57pm
Hal
Tested. Result, one muddy landrover. Abs works, traction control works - lights up on dash (last bit was quite difficult as continental tyres are quite good).
Thanks for all replies, very much appreciated.
Post #338550 16th Jun 2014 7:55pm
