Home > Td5 > Another problem... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17485 |
I had a throttle pot failure on my Td5 Disco2 and the symptoms were quite similar to what you describe.
In effect there was a position of the pedal when the engine would drop back to tickover, press it further and it would be back where it should be. So if you gently and progressively revved the engine the revs would build up, drop off completely, then pick back up where they should be. This defect would log a fault in the ECU but would not cause the MIL to illuminate unless a number of faults were received in a short time, ie pumping the pedal up and down would cause the MIL to come on and the vehicle to enter limp mode. The MIL and limp mode could be cleared by cycling the ignition (and I became quite adept at knocking it into neutral, turning the engine off and restarting it, without stopping the vehicle, but perhaps I shouldn't admit to that)! I seem to remember that the transient faults also disappeared from the fault log when the engine was stopped (but I may be wrong on that), but is certainly took me a while to diagnose it. A new throttle pot and pedal assembly completely cured it. Changing the throttle pot on a Disco is a horrid job unless you have a competent mutant infant with tiny hands and unnaturally long arms do it for you, but I believe that it is quite easy on a Defender. Might well be worth a try if you can't get a fault read-out. You are probably aware that there are three seperate tracks on the throttle pot (in effect three seperate pots) on later vehicles (only two on early ones) and the position reading from all three (or from both on early ones) is compared by the ECU for sanity. As you press the pedal one decreases from 12V towards 0V, one increases from 0V to 12V, and the readings from these summed should always equal 12V. The later ones had the third track added for extra reliability and I can't remember what it does. If there is an irregularity, usually caused by dirct or abrasion on the pot track, it should be detected, but the ECU can't always determine what the position of the pedal actually is so will drop to tickover in certain circumstances. |
16th Jun 2014 8:38am |
Limey Member Since: 18 Oct 2013 Location: Northern Italy Posts: 193 |
Thanks loads Blackwolf.
16th Jun 2014 9:06am |
