Home > Off Topic > if only I had a memory |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
Can anyone help me?
Been searching for a post about rear brake lights connected to ecu fuses etc.....seem to recall seeing a wiring diagram etc. Strange thing I was chatting to someone today about my woes and they mentioned about a Citroën they had which kept having an intermittent problem where there was a drop in power....he kept taking it back to dealers and they were convinced it was just him.....eventually problem was found and it turned out to be a faulty brake pedal switch.... All sounds too familiar... Ps. How do you remove the brake switch cover? Many thanks |
13th Jun 2014 6:05pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Regarding the cover, just apply some force, the cover have 3 latches 2 up and one down if I remember well.
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Jun 2014 6:43pm |
Brill guys. Found it and gonna go have another go at getting cover off without breaking it.
13th Jun 2014 6:46pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
I thought it was running great now I think you might be best seeing a shrink instead of a mechanic
13th Jun 2014 6:55pm |
Blast. Still can't get the switch cover off?
Bottom 2 clips easy peesie ...2 clips...hmmm? |
13th Jun 2014 6:56pm |
It has been (most of the time) but yesterday I felt like popping down to Dover to see the white cliffs!!!!
13th Jun 2014 6:59pm |
Oh. And found out the caravan rear light isn't working so could be another rear plug...had one replaced under warranty already and to cut a long story short I have concerns over the quality of the wiring loom at the rear (well all over really but have good reason to be concerned about the rear) ...
Does anyone know which pins are for brake lights on trailer socket? |
13th Jun 2014 7:08pm |
one last thing....anyone got a phone number for a shrink?
18th Jun 2014 12:19pm |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 |
Does this help?
http://www.defender2.net/forum/topic19534....+electrics Links to an external site near the bottom ... 2009 110 XS Station Wagon |
18th Jun 2014 3:52pm |
Timbar many thanks it would appear I have jumped to the wrong conclusion as only one of the brake lights didn't work.
18th Jun 2014 4:50pm |
Blast me !
I can't find that damn wiring schematic again now? Can anyone help? |
22nd Jun 2014 5:16pm |
Dgardel's link I'll do a search. Promise me the diagrams won't send you into a frenzy that you've a zillion electrical issues first......
****EDIT**** Ear tiz I think....Cut and paste from previous post I made...... Here's the handy link from Dgardel with loads of useful information and the wiring schematics too.... http://api.viglink.com/api/click?format=go...7269580318 ***EDIT AGAIN*** Just checked it and it does still work. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Jun 2014 5:24pm |
Scouts promise. Dib dib dib
all that info should keep me quiet for a while Thank you v much.....don't suppose you can show me where that diagram is that shows the power feed to clutch switch and brake switch if my memory serves right? |
22nd Jun 2014 6:02pm |
417-01, 417-02. For the brake.
303-14 for the clutch and brake switch feeds into the ECM. Christ Caterham, give me your address and if you can give me a couple of hours notice next time you feel the urge coming on to take a dump give me a tinkle and I'll pop right round and wipe your crimper for you when you're done. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Jun 2014 6:27pm |
