Home > Puma (Tdci) > bonnet hinge bush
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
bonnet hinge bush
my o/s bonnet bush is bouncing up and down in the hinge. I bought a new genuine bush but its no different.
any suggestions? or do i get a hammer out and something to protect the paint.. like a bit of wood wrapped in a cloth.
I bodged it for now with a bit of rubber band in between the gap but it falls out when opening the bonnet. 1953 80"
1987 mini city e
2011 90"
Post #337896 13th Jun 2014 10:50am
mk1collector
Take it back under warranty
Post #337899 13th Jun 2014 11:10am
MR_JAMES
warranty expired a month ago. 1953 80"
1987 mini city e
2011 90"
Post #337902 13th Jun 2014 11:14am
mk1collector
Big Cry in that case it's a very light hammering with plenty of paint protection. I'd still try and see if the dealer would do it under warranty though, worst they can say is no
Post #337903 13th Jun 2014 11:18am
shaggydog
I had same problem with mine, the spare (and now I have found out badly adjusted slam plate) caused it to rattle and wear and eventually they broke.
I copied an original parts hinge bush and found that it was smaller than the ones I had put in previously.
My bulkhead is coming out soon so I gave it a few bangs and the plates do not respond well to having whack from a hammer as the plate uncurls or bends on the bulkhead first before it alters the angle of the curve. it made a hell of a mess and I can highly recommend you DON'T DO THIS.
My solution was to make my own from nylon which has cured the problem though it is somewhat annoying that I had to take 2 attempts at it due to LR's inconstant bonnet bush sizes. Having had to change about 7 in the last 3 years Rolling Eyes
If you have a pair of calipers handy have a measure of the old original and the new one and reference it with the side that doesn't rattle. that may give you an idea if it is the curl at fault or you have a shrunken bush.
As a quick fix though, you can cut a slice of old plastic like a credit card and wedge it in underneath Thumbs Up
Post #337910 13th Jun 2014 12:01pm
JWL
On my old 90 I cut some strips of inner tube , laid it in the curl then put the bonnet back on. That cured it.
Post #337912 13th Jun 2014 12:29pm
landy andy
Buy updated/security hinges?
Andy
Post #337916 13th Jun 2014 12:51pm
