Home > Technical > Alloy wheel question |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
Is it possible to spray (successfully ) alloy wheels? 1982 88" 2.25 diesel
10th Jun 2014 7:21pm |
O.K. Just thinking of white Land Rover boost alloys 1982 88" 2.25 diesel
10th Jun 2014 7:44pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Thort the same thing my self funnily enough,bit too much white on this'un tho, imo.
Pov.spec,ftw. 2006, 110,TD5. |
10th Jun 2014 7:54pm |
Yep,mo sprayed some Deep-Dish Defender alloys a while back An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
10th Jun 2014 8:28pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
Had these sprayed. The key is in the prep, but its much better than powdercoating.
Click image to enlarge Defender puma dormobile camper |
11th Jun 2014 5:50am |
Two fine looking Land Rovers Wonder how much prep work it would take to get the wife to look that good. Probably need a panel beater on the team 1982 88" 2.25 diesel
11th Jun 2014 8:39am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20489 |
You'll get a better gloss with the paint, as mentioned prep is important.
With the paint at least if you get damage you can re-spray. Be careful of runs though on an un-even surface, thin even coats would be best. |
11th Jun 2014 9:15am |
I'd really like to get Boost Alloys done white. Can the tyre fitter fit the tyres without blemishing the paintwork?
Thanks for the comments and photos 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
11th Jun 2014 9:58am |
Was just checking out the photos on this thread and the wife happened to spot the above post. Damnit, looks as though my account on this site was "hacked" and the above post was placed by some cyper hacker. Must tell Martin to up the security on this site. Well that's what I told the Mrs anyway. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
11th Jun 2014 10:37am |
Yes tyres can be fitted without damaging the paint as long as it's a half-decent paint and not chocolate.. If you go through life with your head in the sand....all people will see is an ar5e!!
11th Jun 2014 10:38am |
Will have a word with the local tyre fitters just to make sure he can do a good job. 1982 88" 2.25 diesel
11th Jun 2014 10:42am |
