Home > Maintenance & Modifications > Fitting a bulkhead removal bar |
r21 Member Since: 25 Apr 2014 Location: Merseyside Posts: 77 |
Think I've found the answer to my first question, found a blog detailing it and lip is clearly shown so the puma and td5 aren't different, link to the blog http://projectd90.blogspot.co.uk/2011/05/b...part3.html
Still any tips on removing the last bit being removed would be appreciated, hacksaw job I presume? |
8th Jun 2014 6:35pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I thought the hardtop had to be removed ?
9th Jun 2014 7:40am |
I've read you can fit it without removing the hardtop although it does make it more difficult - I guess I'll find out soon enough if its possible
9th Jun 2014 7:49am |
You can fit the bulkhead removal bar without taking the sides and roof off however its not easy! After much sweating and swearing it can be done by removing the 2 bolts nearest the front seat belt holding the bottom of the side panel to the tub and the also the seat belt bracket, then if you open the door the side panel can be pushed out to reveal the tub capping - I drilled from underneath the capping and then just dropped the bolts through to minimise the time the panel was pushed out, its all gone back together ok and the panels aren't damaged or out of alignment.
9th Jun 2014 2:13pm |
