Home > Puma (Tdci) > 2.2 TDCI recall |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 |
yeah im on the 3rd pipe now and going in next week or so to Taunton for the recall r360
29th May 2014 5:37pm |
on your third pipe , when it went in for the first one they must have seen what caused it , could they not think to themselves this is going to happen again and do something about it , even put a cable tie round it ,bit of old pipe put round outside anything really there must be a hundred ways to fix or help it to not happen again
I just would never give a customers car back knowing it would ever happen again or least say I have tried to help to stop it |
29th May 2014 5:57pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Which pipe is causing the trouble? Is this something we can prevent by cable tieing the pipe ourselves? 110 Hardtop
29th May 2014 6:20pm |
There was a recall for a chafing pipe over two and a half years ago......
http://www.defender2.net/forum/topic10264....afing+pipe Another thread..... http://www.defender2.net/forum/topic21673....ooler+pipe If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th May 2014 6:26pm |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 |
Mine was in today and they told me about this issue being flagged up for checking as I handed it over.
Got a nice FL2 SD4 for the day: much more enjoyable than I thought. Phoned this afternoon to check on completion to be told that they didn't have the parts for the lights so the car won't be ready until tomorrow lunchtime. Don't you just love it when a plan comes together? 1970 Series 2A 88" |
29th May 2014 6:47pm |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
Can you ask for the replacement part number? Is it the last elbow into the engine?
30th May 2014 1:30am |
So a late 2013 LR should have the corrected hoses from the factory then 110 Hardtop
30th May 2014 10:55am |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
I don't think there is a "corrected" hose as the moment. I'm on my 3rd hose in a year. Mine is a '13' reg.
It went in for is first service last month and had another hose fitted. The "correction" appears to be that they now fit a zip tie to hold the hose in place Maybe a set of silicon hosed would fix this as the problem seems to occur when the current hose expands under pressure and heat. The dealer mentioned that ironically silicon hoses would fix the issue but invalidate the warranty! Well done Land Rover. |
30th May 2014 11:45am |
^^ QQThe dealer mentioned that ironically silicon hoses would fix the issue but invalidate the warranty! QQ
Think that is exactly a subject to bring to the attention of Mike of Land Rover Cutomer Relations to solve. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th May 2014 11:52am |
So here is the "corrected" hose. I just went and took some photos of the 'post recall' work. Check out my new Land Rover genuine ZIP TIE
Not really worth the 50 mile round trip. If i were you i wouldn't bother just throw some gaffer tape at it and save yourself the diesel. If the hose is so unsuitable that it has to be zip tied out of harms way you would think Land Rover would offer a non-expanding hose as a fix not just bodge it. I fully expect to consume at least 3 hoses a year with 12,000 miles annual mileage. Genius. Click image to enlarge Click image to enlarge |
30th May 2014 12:10pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Me too.
just have my service done yesterday on my 2.2 puma fenda I was told there will be an upgrade of the turbo hose in the near future ( on top of the previous fix which invloves additional bracket on the alternator and a safty strip) will see how it goes theoretically, this will be the third version of turbo hose fix... Cheers Martin |
5th Jun 2014 3:58am |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
Mine is also due.
I have been told there is a modified bracket (more than a cable tie). I don't know if every vehicle gets this though. |
5th Jun 2014 6:30am |
If any of you do have the modified bracket solution I would be most grateful if you could post some photos. I would like to find out from my dealer why I had a zip tie fix and others have a 'proper' solution.
Thanks. |
5th Jun 2014 8:06am |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Apparently mine was done this week. I was told it's no longer a cable tie, but a new bracket that fixes, at one end, to the alternator. Presumably it's fixed to the pipe at the other.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
5th Jun 2014 4:12pm |
