Home > Puma (Tdci) > 2.2 TDCI recall
G1BB0
United Kingdom 1997 Defender 90 300 Tdi PU Arles Blue
2.2 TDCI recall
Hi
Just had contact from Taunton LR about a recall on my Defender - apparently it is to do with replacing an air pipe from the intercooler (might have that wrong) due to problems with current design failing, leading to power loss.
All booked in for FOC change in a couple of weeks. Anyone else been contacted about this?
Post #334369 29th May 2014 11:55am
Defender-Stu
yeah im on the 3rd pipe now and going in next week or so to Taunton for the recall r360 Thumbs Up
Post #334420 29th May 2014 5:37pm
munch90
on your third pipe , when it went in for the first one they must have seen what caused it , could they not think to themselves this is going to happen again and do something about it , even put a cable tie round it ,bit of old pipe put round outside anything really there must be a hundred ways to fix or help it to not happen again
I just would never give a customers car back knowing it would ever happen again or least say I have tried to help to stop it
Post #334424 29th May 2014 5:57pm
pob1968
Which pipe is causing the trouble? Is this something we can prevent by cable tieing the pipe ourselves? 110 Hardtop
Post #334428 29th May 2014 6:20pm
K9F
There was a recall for a chafing pipe over two and a half years ago......
http://www.defender2.net/forum/topic10264....afing+pipe
Another thread.....
http://www.defender2.net/forum/topic21673....ooler+pipe If you go through life with your head in the sand....all people will see is an ar5e!!
Post #334431 29th May 2014 6:26pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Mine was in today and they told me about this issue being flagged up for checking as I handed it over.
Got a nice FL2 SD4 for the day: much more enjoyable than I thought. Smile
Phoned this afternoon to check on completion to be told that they didn't have the parts for the lights Question Exclamation so the car won't be ready until tomorrow lunchtime.
Don't you just love it when a plan comes together? Rolling Eyes 1970 Series 2A 88"
Post #334438 29th May 2014 6:47pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Can you ask for the replacement part number? Is it the last elbow into the engine?
Post #334516 30th May 2014 1:30am
pob1968
So a late 2013 LR should have the corrected hoses from the factory then Wink 110 Hardtop
Post #334555 30th May 2014 10:55am
Jim_Bean
I don't think there is a "corrected" hose as the moment. I'm on my 3rd hose in a year. Mine is a '13' reg.
It went in for is first service last month and had another hose fitted. The "correction" appears to be that they now fit a zip tie to hold the hose in place Shocked
Maybe a set of silicon hosed would fix this as the problem seems to occur when the current hose expands under pressure and heat.
The dealer mentioned that ironically silicon hoses would fix the issue but invalidate the warranty!
Well done Land Rover.
Post #334562 30th May 2014 11:45am
ericvv
^^ QQThe dealer mentioned that ironically silicon hoses would fix the issue but invalidate the warranty! QQ
Think that is exactly a subject to bring to the attention of Mike of Land Rover Cutomer Relations to solve. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #334564 30th May 2014 11:52am
Jim_Bean
So here is the "corrected" hose. I just went and took some photos of the 'post recall' work. Check out my new Land Rover genuine ZIP TIE Evil or Very Mad
Not really worth the 50 mile round trip. If i were you i wouldn't bother just throw some gaffer tape at it and save yourself the diesel.
If the hose is so unsuitable that it has to be zip tied out of harms way you would think Land Rover would offer a non-expanding hose as a fix not just bodge it.
I fully expect to consume at least 3 hoses a year with 12,000 miles annual mileage. Genius.
Post #334567 30th May 2014 12:10pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Me too.
just have my service done yesterday on my 2.2 puma fenda
I was told there will be an upgrade of the turbo hose in the near future ( on top of the previous fix which invloves additional bracket on the alternator and a safty strip)
will see how it goes
theoretically, this will be the third version of turbo hose fix...
Martin
Post #335874 5th Jun 2014 3:58am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Mine is also due.
I have been told there is a modified bracket (more than a cable tie). I don't know if every vehicle gets this though.
Post #335881 5th Jun 2014 6:30am
Jim_Bean
If any of you do have the modified bracket solution I would be most grateful if you could post some photos. I would like to find out from my dealer why I had a zip tie fix and others have a 'proper' solution.
Thanks.
Post #335895 5th Jun 2014 8:06am
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Apparently mine was done this week. I was told it's no longer a cable tie, but a new bracket that fixes, at one end, to the alternator. Presumably it's fixed to the pipe at the other.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #335969 5th Jun 2014 4:12pm
