Home > My Defender > g-macks 110 300 tdi thread
Page 10 of 25 <123 ... 91011 ... 232425>
shaggydog
I got a genuine replacement ball joint from my local main dealer for about £7 and fitted in about half a hour.
Check your pm's in about 5 mins have something to send you Wink
Post #335318 2nd Jun 2014 8:12pm
shaggydog
Never mind found a way to upload it!
Hope it helps Thumbs Up
Post #335322 2nd Jun 2014 8:28pm
kipperthedog
g-mack wrote:
cheers GOG! was unaware of that kit!!
+1! Thumbs Up
I have to do this too.
Post #335507 3rd Jun 2014 7:25pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
looks a great Landie very interesting read.
Post #335659 4th Jun 2014 11:35am
g-mack
Post #335941 5th Jun 2014 12:28pm
g-mack
3 knocks at the door this morning.
1st brang me a steel ruler! and a new 24" breaker bar
2nd knock a paddock oil tray/container and a new set of metric feelers
3rd knock came this
£100 !! used but cleaned pressure checked and skimmed!!!
need to buy a valve clamp from paddocks so i can change the stem seals then order some head bolts and a gasket kit, once ive got that it's time to open the old tdi up and see why its smoking and drinking so heavily! My 109 thread
my youtube channel
Post #335944 5th Jun 2014 12:34pm
steventheplumber
Christmas come early
Post #335946 5th Jun 2014 12:40pm
g-mack
kinda! would much rather be spending on snazzy tdci seats or posh wheel carriers! lol but needs must! My 109 thread
my youtube channel
Post #335949 5th Jun 2014 12:46pm
steventheplumber
I know how you feel
Post #335964 5th Jun 2014 3:15pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
As above Big Cry
Post #336025 5th Jun 2014 7:36pm
steventheplumber
I was going to use that one Rolling Eyes
Post #336028 5th Jun 2014 7:45pm
grumpy old git
There's a good guide to replacing the pitman arm joint here if you need it Thumbs Up
Drop arm ball joint change insitu
Post #336100 6th Jun 2014 6:03am
TD5_dan
2001 Defender 110 Td5 CSW Java Black
3rd knock came this
Might have been cleaned and pressure tested but that ain't been skimmed. What's wrong with your old cylinder head. Don't go changing yours unless you really have to because it's going to be hard working out what head gasket thickness you want. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #336455 7th Jun 2014 6:08pm
g-mack
Dan how do you know it hasn't been skimmed? i should have said recently skimmed, ie its been back on a car for 8000 miles! dont know about mine yet. all mine is doing is losing water, alot!! and its smoking it out the exhaust. bought this head as a cheap replacement should i find something bad when mine comes off. ive had a good look over this head with a steel rule and .08mm feeler and it seems OK there are place where a .04 will go under, which i though were strange for a skimmed head but then thought maybe they didnt take enough off! My 109 thread
my youtube channel
Post #336463 7th Jun 2014 6:34pm
TD5_dan
Ah that makes more sense was purely the fact it doesn't look freshly skimmed mate. For that money it's worth it as a back up anyway. You may not even need it then, if you can get away with a light skim of your original head still and put the next thickness head gasket on you will be able to keep closer to the original engine spec and tolerances but you will have to see what you confronted with. I had a 95 disco 300 that i changed the head gasket on its a nice easy engine to do a head swap on at least. Good luck, hope you get it sorted 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #336516 7th Jun 2014 10:01pm
