Home > In Car Electronics > "Noddy's guide" to fitting a basic radio to a new
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Proud owner of a new Defender which I bought without a CD/Radio but is apparently radio ready i.e. aerial fitted
and under dash speakers. Anyone got a idiots guide to fitting a basic radio.....and what's needed?
Post #335579 3rd Jun 2014 10:52pm
Find all your connections first and report back what you have inc any plugs etc.
You should have primary power and the speaker connections tucked away somewhere.
Once you've defined that you've found everything and the speakers are all connected up then you can progress on from there fitting wise.
I'd imagine behind the dash you'll find the HU plugs which are probably 2012> specific and also factory blanked (removable) for production etc until used.
The ends you'll probably have to fish out will be the speaker ends which should roughly speaking be located behind each speaker give or take.
Thumbs Up
Post #335581 3rd Jun 2014 10:58pm
Dave Bellis
Noddy's Guide
Thanks for the reply, I presume I need to remove the radio blanking plate to find any connections I guess it is just a push fit item...I have no knowledge of the connector types etc. anywhere I can get specific wiring info..?
Post #335583 3rd Jun 2014 11:26pm
Not that I am aware of, for your age Defender it should be grey.
It's location alone will tell you it's purpose, it'll be at the back of the middle of the dash.
And yes you'll need to gain access to behind there also.
Post #335585 3rd Jun 2014 11:31pm
MartinK
This thread may prove useful: http://www.defender2.net/forum/topic5492.html
It shows the radio connections in the very 1st pic (pale plug for power connections, brown plug for speaker connections). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #335596 4th Jun 2014 6:11am
jimbob7
Also dump the factory speakers for somethin better,almost anything is better than stock if you get the same size (100mm) its a straight swap.Or go up a size (130mm) and modify slightly with mdf speaker rings. Pov.spec,ftw. 2006, 110,TD5.
Post #335606 4th Jun 2014 7:13am
Dave Bellis
Noddy's Guide to fittng a radio
Thanks for the replies, the photo in the thread was really useful I'll remove the blanking plate and see what it reveals.....when have a few seconds...
The radio is really for "her who burns the dinner", so I'm not too bothered about the speakers, I'm more interested in the drive, I've waited far too long before getting my first Defender and I must say what an experience.
I can never see me wanting anything else.
Dave..
Post #335635 4th Jun 2014 9:16am
Dave, remember the photo in that link is on an 07 2.4 like mine not a 2.2 that you have.
The plug will be different, I think from memory it's grey and it's a single plug.
The above adaptor will give you the idea, which is available from Mud or Nexxia. (Which you will need)
The black plugs are the male ISO end (to HU) and the grey end for the male Defender plug that you should have.
For you just plug in and that's it, previous to 2012 it was even easier being ISO as standard without needing an adaptor.
Post #335642 4th Jun 2014 9:41am
Dave Bellis
Thanks, as you said a grey plug and coax connector neatly taped behind the dash, I have ordered an adapter from Nexxia again thanks for the info...
Nearly there, does a single DIN standard radio fit directly into the slot vacated by the blanking plate (any plate needed)and I presume all radio connections are now standard as per the adaptor you mentioned.
Post #335719 4th Jun 2014 4:51pm
Good news. Thumbs Up
You'll need a single din cage too, what ever manufacturer you go for I would go for their cage.
There is universal but that's what I'd recommend.
Also a pair of keys for the manufacturer too.
This keeps it physically secure and for security purposes.
Post #335723 4th Jun 2014 5:09pm
Dave Bellis
Thinking of fitting an Alpine UTE 72 BT which has all "the boss" requires any comments, apparently comes with cage but don't know about the strapping................
Post #335856 4th Jun 2014 10:48pm
ZeDefender
Before you dump the speakers, get an active sub, a small one like this will do :
http://www.ebay.co.uk/itm/Kenwood-KSC-SW11...27da488304
It makes an incredible difference to the sound. I tried changing all the speakers to good replacements but ended up refitting the original ones because they sound warmer. It's not just me - several colleagues have also mentioned how good the sound is Thumbs Up Tell someone you love them today because life is short.
Post #335873 5th Jun 2014 3:54am
Dave Bellis
noddy's guide to fitting a radio
All done, thanks to you lot...Incidentally there a was a second small grey plug taped in with the plug in the photo with nylon locating studs at the side, out of curiosity anyone know what this is for???
Post #337345 10th Jun 2014 9:25pm
Cuthbert
Can I ask what your technique was for removing the blanking plate over the radio slot on the dash. I keep meaning to fit the radio that is currently sitting on the kitchen shelf.
Post #337370 10th Jun 2014 10:00pm
Could any of you chaps get a photo of this blanking plate at all? I'd be interested to see these if possible as I haven't actually seen one.
Post #337372 10th Jun 2014 10:05pm
