Home > Puma (Tdci) > Lanky & clanky transmission, snatchy take up... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Dare I ask which dealers you refer to....i wonder if it's been Caterham'd by the same dealers.
New turbo fixed my kangaroo 'ing........ Just wondering.......do you suspect your clutch could be excessively stiff? As daft as it sounds some lube on mine seemed to help no end - and not necessarily with the stiffness |
3rd Jun 2014 7:31pm |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
Timbar, the death rattle I think Blackwolf is talking about is a definite, unmistakable rattle. I have had this rattle, it's from broken springs in the clutch assembly. I believe the clutch has been upgraded somehow and no longer suffer from breaking springs.
In your youtube clip, what I could hear is normal engine noise pending clutch in or out. Mine does this as well but it's not the dying clutch rattle. |
4th Jun 2014 4:36am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17363 |
That actually sounds fairly normal to me, it isn't the clutch death rattle. The best test for the death rattle is to shut off the engine with the clutch in, when the rattle will be unmistakable. |
4th Jun 2014 8:02am |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 |
Cheers 2009 110 XS Station Wagon
4th Jun 2014 8:18am |
Fish Member Since: 21 Jan 2014 Location: United Kingdom Posts: 58 |
This pogoing that you can't get out of without dipping the clutch is very similar to what happens when you bypass the clutch switch to get rid of the rev hold. Is this working properly, ie do the revs hold when you change up. If they don't and drop straight back down I'd suggest the clutch switch is knackered and a new one will fix it.... It is a plug located on the top of the clutch hydraulic reservoir. You can shot it out to get rifd of the rev hold but then it Kangeroos and shunts...
Have a look at it and see what it is doing, with a multimeter clutch depressed should give a made contact clutch out ie driving should be open contact... Hope it helps, at least worth checking... |
4th Jun 2014 8:43pm |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 553 |
I've had vibration/knocking/play in the driveline and has taken 18 months and 5 seperate trips to finally sort. Hopefully fully rectified when the car comes back tomorrow and done so by taking to a different dealer with a fresh pair of eyes.
Originally loose propshaft bolts. Now found worn drive flanges and wear to parts in the transfer box The first dealer who had it on 4 seperate occasions were never really that interested in looking for a problem but thankfully Sturgess Leicester took only an hour to have a proper look and find the issue. Good luck and change dealers if in doubt |
4th Jun 2014 9:00pm |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Clutch seems fine and not stiff. The dealer is Guy Salmon, Knutsford. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
4th Jun 2014 10:26pm |
The rev' hold is working correctly. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
4th Jun 2014 10:27pm |
I took the comments off here to the dealer today, but nowt's been done on the drive line issues as Land Rover have not changed their mind on it being "satisfactory". Looks like I may have to change dealers (from Guy Salmon Knutsford), followed by manufacturer! And I haven't mentioned the other faults, such as the three visits to fix the heater to stop it bleeding past the lower vents when its on screen. It's now almost correct, but on full cold it now blows luke warm, followed by all the sealer that's on the door frames from when they resealed the windscreen, and they still haven't removed it all! Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
4th Jun 2014 10:38pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Just a thought, have you/they change the throttle pedal potentiometer..? On my TD5 I get a slight pogo effect at low speeds in 2nd/3rd gear and it seems to be a combination of a dead spot on the potentiometer causing the car to slow, which in turn causes my foot to press a little harder on the pedal going past the dead spot but giving it a bit more throttle.
Not sure if that's clear..! Cheers Simon Ps I've always had great service from Guy Salmon in Stockport, might be worth a visit. |
5th Jun 2014 5:46am |
Although I have no evidence either way to suggest what they have or haven't checked, recent pm's and emails to Mike in LR's customer services and the service manager at Guy Salmon Knutsford gives me the feeling that the basic stuff such as the tightness of bolts, the condition of engine and gearbox mountings, and that sort of thing, may not have been checked, so I doubt the throttle has been looked at. I don't know either way on these checks, but I asked last night via an email to the dealer what had been checked since this was first brought up at the service last September. However, all I got back was that the technician went through in detail what had been done yesterday. This "detail" concerned work done during this last visit, which didn't including anything on the pogoing issue.
Both myself and LRCS are waiting for a reply on what has or hasn't been checked from the dealer. Regarding the Stockport branch, that's even further away. Cheers for the extra info' folks. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
5th Jun 2014 4:25pm |
Please let me know how you get on with yours. It may be that Sturgess get my business if they are successful, and I'll save around 30 miles per round trip. To date I've done over 700 miles to the dealer on this issue (with a few others at the same time) going to and from Guy Salmon Knutsford. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
5th Jun 2014 4:30pm |
I should get the car back tomorrow now. There was a delay with a seized bolt and them needing an engineer visit the dealer and resolve. I've no idea who this engineer is or why one is needed but hopefully the car will come back feeling better.
5th Jun 2014 6:46pm |
Cheers.
Thanks for letting me know. I've just been on to LRCS again, and the next option will be to take it to another dealer. Which one in Leicester did you take it too? There seems to be serveral in that area. On the plus side, going to Leicester will save me 40 miles per round trip. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
6th Jun 2014 11:20am |
