![]() | Home > Tdi > Have i used the wrong engine oil |
what grade did you use ?
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Sorry 10w40 Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
few years ago now ,but I used magnetec 10/40 in my 200tdi
and if it say petrol / diesel on it then must be ok |
Cheers for that i was just worried with the 200 being a turbo engine but as you say should be ok
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
if you go to castrol web site there is a oil selector and you put your reg number in and it tells you what oil , amount etc
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
a 200 will run on almost anything. Not a fussy tart like these modern things!
