Home > My Defender > g-macks 110 300 tdi thread
Page 9 of 25 <123 ... 8910 ... 232425>
g-mack
must say im not impressed with the display on the TM2 watchdog, its really hard to read in daylight!!
 My 109 thread
my youtube channel
Post #328682 6th May 2014 10:01am
g-mack
i have had a gradual droning noise lately that is getting worse. it is rev/load dependent. was convinced it was drivetrain related, had my props off greasing everything etc. now over the last few days it has got worse. this is good though as it makes it easier to work out what it is ( sometimes) i got to thinking it actually sounds like it may be exhaust related. low and behold the joint between the turbo and the downpipe is blowing!! My 109 thread
my youtube channel
Post #330744 13th May 2014 12:43pm
g-mack
right all 3 nuts on the downpipe to turbo needed tightening. still got the droning though. Sad im hoping ive also cured a rattling pinking sound at revs, as the washers would be rattling around with the nuts not being tight.
maybe its my mid box baffles, its developed from a drone to a boom and can also here it when stationary and revving!
i hate chasing noises! it can get expensive! My 109 thread
my youtube channel
Post #330751 13th May 2014 1:29pm
g-mack
cleaned and regreased rear bearing yesterday messy job! but cured me wobbly wheel! My 109 thread
my youtube channel
Post #331391 16th May 2014 4:08pm
g-mack
Fitted and wired new td5 clock today better than the blanked hole it came with
 My 109 thread
my youtube channel
Post #332689 21st May 2014 11:18pm
g-mack
Also removed handbrake drum to give it a good clean as it knocks when I come to a standstill. My 109 thread
my youtube channel
Post #332690 21st May 2014 11:21pm
g-mack
New bits to put on!! Not glamorous but essential!
This is the problem with old cars, all your cash seems to go on boring essential repairs rather than fun mods!!!
Looks fairly simple swap My 109 thread
my youtube channel
Post #332768 22nd May 2014 12:07pm
g-mack
Fitted new servo today
Old and new
PLENTY OF HELP FROM THE MUT!
brakes are sooooooooooooooo much better now!!! My 109 thread
my youtube channel
Post #333835 26th May 2014 9:26pm
g-mack
MOT booked for 10am sat! wish me luck! My 109 thread
my youtube channel
Post #334237 28th May 2014 7:39pm
g-mack
removed manifold to have a look if any of the ports were clean with water, they are not so maybe my head isnt cracked!
cleaned surfaces and replaced gaskets too in the hope of curing droning noise. didn't help.
 My 109 thread
my youtube channel
Post #334724 31st May 2014 12:15am
g-mack
passed MOT today!!
8 advisories!!!!
only one is a bit of a worry!
1. play in pitman arm ball joint (worst job to sort but cheap!)
2. NS rear pads thin
3. OS rear pad thin
4. OS ARB bush slight play
5. engine cover fitted! (none issue)
6. rear passenger seats missing !!! (none issue)
7. hub seals weeping
8. oil leak!!! (obviously its a defender)
so all super quick and easy fixes aprt from drop arm ball joint!
not bad for 19 years old!! My 109 thread
my youtube channel
Post #335247 2nd Jun 2014 3:31pm
shaggydog
Drop arm is really simple. I did mine on the drive last year was dead simple.
Does yours have the drop out pin type or is it a split off from the bottom of the Steering Box job?
Glad to see it passed for another year though Very Happy
Post #335272 2nd Jun 2014 5:20pm
g-mack
not sure actually! will have a look tomorrow and take a piccy.did you just change ball joint or whole drop arm? My 109 thread
my youtube channel
Post #335287 2nd Jun 2014 6:46pm
grumpy old git
If you decide to replace the ball joint insitu invest in the Br*tpart tool . I did ours last time and it makes it easy, typically though it ran out of thread pushing the old upper cup out but a socket over the bolt gave it enough Thumbs Up
DA1125
Post #335305 2nd Jun 2014 7:33pm
g-mack
cheers GOG! was unaware of that kit!! My 109 thread
my youtube channel
Post #335311 2nd Jun 2014 7:52pm
