Home > My Defender > g-macks 110 300 tdi thread |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
must say im not impressed with the display on the TM2 watchdog, its really hard to read in daylight!!
Click image to enlarge My 109 thread my youtube channel |
6th May 2014 10:01am |
i have had a gradual droning noise lately that is getting worse. it is rev/load dependent. was convinced it was drivetrain related, had my props off greasing everything etc. now over the last few days it has got worse. this is good though as it makes it easier to work out what it is ( sometimes) i got to thinking it actually sounds like it may be exhaust related. low and behold the joint between the turbo and the downpipe is blowing!! My 109 thread
13th May 2014 12:43pm |
right all 3 nuts on the downpipe to turbo needed tightening. still got the droning though. im hoping ive also cured a rattling pinking sound at revs, as the washers would be rattling around with the nuts not being tight.
maybe its my mid box baffles, its developed from a drone to a boom and can also here it when stationary and revving! i hate chasing noises! it can get expensive! My 109 thread my youtube channel |
13th May 2014 1:29pm |
cleaned and regreased rear bearing yesterday messy job! but cured me wobbly wheel! My 109 thread
16th May 2014 4:08pm |
Fitted and wired new td5 clock today better than the blanked hole it came with
21st May 2014 11:18pm |
Also removed handbrake drum to give it a good clean as it knocks when I come to a standstill. My 109 thread
21st May 2014 11:21pm |
New bits to put on!! Not glamorous but essential!
This is the problem with old cars, all your cash seems to go on boring essential repairs rather than fun mods!!! Click image to enlarge Looks fairly simple swap My 109 thread my youtube channel |
22nd May 2014 12:07pm |
Fitted new servo today
Old and new Click image to enlarge Click image to enlarge PLENTY OF HELP FROM THE MUT! Click image to enlarge Click image to enlarge Click image to enlarge brakes are sooooooooooooooo much better now!!! My 109 thread my youtube channel |
26th May 2014 9:26pm |
MOT booked for 10am sat! wish me luck! My 109 thread
28th May 2014 7:39pm |
removed manifold to have a look if any of the ports were clean with water, they are not so maybe my head isnt cracked!
cleaned surfaces and replaced gaskets too in the hope of curing droning noise. didn't help. Click image to enlarge Click image to enlarge My 109 thread my youtube channel |
31st May 2014 12:15am |
passed MOT today!!
8 advisories!!!! only one is a bit of a worry! 1. play in pitman arm ball joint (worst job to sort but cheap!) 2. NS rear pads thin 3. OS rear pad thin 4. OS ARB bush slight play 5. engine cover fitted! (none issue) 6. rear passenger seats missing !!! (none issue) 7. hub seals weeping 8. oil leak!!! (obviously its a defender) so all super quick and easy fixes aprt from drop arm ball joint! not bad for 19 years old!! My 109 thread my youtube channel |
2nd Jun 2014 3:31pm |
not sure actually! will have a look tomorrow and take a piccy.did you just change ball joint or whole drop arm? My 109 thread
2nd Jun 2014 6:46pm |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
If you decide to replace the ball joint insitu invest in the Br*tpart tool . I did ours last time and it makes it easy, typically though it ran out of thread pushing the old upper cup out but a socket over the bolt gave it enough
DA1125 |
2nd Jun 2014 7:33pm |
cheers GOG! was unaware of that kit!! My 109 thread
2nd Jun 2014 7:52pm |
