Home > Camping, Caravanning and Holidays > Ozpig Stove
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Ozpig Stove
Does anyone have a Ozpig stove and if so who stocks them in the UK, as I'm struggling to find anyone on the Internet.
I'm considering a Frontier if I can't find one, but the Ozpig looks more versatile, from what I've seen on YouTube.
Post #335133 1st Jun 2014 9:17pm
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
Hi
I have had one for a few years now. It appears their UK website no longer works, and the person wo use to do the demo at various shows now appears to be showing off the Frontier version. Myers - Somewhere on Salisbury Plain
Puma 90 Hardtop (XS Spec)
Post #335237 2nd Jun 2014 2:27pm
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
An alternative maybe.
I to have been looking for an ozpig or something similar, yesterday I came across this
http://dunsterhouse.co.uk/bbq-stoves/hope-bbq-stove
and I think it looks pretty good. Has anybody out there seen or used one of these stoves? 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #335883 5th Jun 2014 6:38am
jayaway44
The cooking surface looks far bigger on the Dunster one than on both the Ozpig and the Frontier stoves. 2.2 2012 110 utility Orkney Grey
Also
Previous
90 TD5
Discovery 3
Early Discovery.
Post #336591 8th Jun 2014 10:30am
a13x
I have an ozpig, cobb, weber BBQ, coleman petrol burner and also a tentipi stainless steel wood burner.
I've taken the ozpig out a couple of times and it's pretty cool but does have plenty of drawbacks
It's very heavy, takes a while and difficult to get hot (I use charcoal to get the heat for cooking) and the cooking surface is small, I slide the plate out the way, place a flat griddle over the opening for which the pan can sit.
The other issue is it really doesn't give off that much heat, if you want the warmth you will almost have to sit on top of the thing to feel the heat.
For me the tentipi burner is brilliant, gets very hot quickly, takes good size logs, decent flue and has a good area to heat the kettle in the morning. That being said, if you are wanting something to slow cook like the guys in SA do, then the ozpig would be great.
Post #336599 8th Jun 2014 11:01am
