Home > Puma (Tdci) > Puma bad running |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Blocked fuel filter - (I picked up a bad batch of diesel from Mont St Michel services a few weeks ago) - new filter seems to have cured it.
Bad connection on speedometer sensor on gearbox, given me problems in the past. Good luck Keith |
29th May 2014 4:50pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
id start with the filter too, causes all kinds of issues and an easy fix.
JUST BE CAREFUL TO FILL UP THE NEW FILTER WITH DIESEL! otherwise you'll have a pig of a time trying to get the air out of the system. And make sure its screwed on tight and the little drain cap is done up at the bottom or you'll have trouble too... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th May 2014 4:53pm |
