![]() | Home > Maintenance & Modifications > Rear door/wheel rattle |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
I'll check for you later, but I don't think there's any spacers on mine and the wiper wotks fine. No doubt somone will give you a more definitive answer
![]() Steve |
Potter Member Since: 21 Aug 2013 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
Is it a different wiper or is it bent maybe?
The studs on the carrier are adjustable to a degree! You should be able to wind them out sufficiently for a boost.
![]() Treat every day as if it is your last....one day you will be right!! |
Cheers but I'm not sure how moving the studs out are going to space it away from the wiper though? The back of the wheel sits against the carrier...?
I shall say it again....The studs are adjustable. Look at the picture below. The flat nut will wind out allowing you to space the wheel away from the wiper without the need for spacers. The wheel sits against the nuts NOT the carrier. I removed one from the stud to show you.
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Cheers for that!
I don't have the flat nuts on mine... anyone know a part number? |
Anyone know the part number or point me in the right direction for the flat nuts?
Your choices are using the standard steel wheel nuts on the studs. OK does not give such a large bearing surface as the flat ones.
Have no idea about part number but I know Safari Equip makes them for their wheel carriers. You can either phone them direct on 01274 835500, ask for Tom. Or I could pick up a set for you next time I am at te factory. Please note these are not cheap as they have to be cut out of flat sheet, threaded individually etc etc. Since your 90 has only done 5k miles how about asking your dealer for a set? Brendan |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
How about using some large flat washers to space the wheel away from the door,simple and cheap. 2005 Td5 90 XS
Steve |
I've actually got some standard wheel nuts from the steel wheels behind the wheel and then the boost nuts... but something is still rattling.
Could it be something else rattling? Like the door latch? Can the door latch be adjusted? Thanks for your help guys |
Yes you can adjust the door latch and make the door shut tighter, but only a small amount. Loosen the torx screws on the latch and movbe it in a bit. Original Member Pie n Pea Club.
110 HCPU Tipper |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
I'm amazed you managed 5k miles before something started to rattle
![]() if you're planning on keeping it long term it would be worth looking into a wheel carrier of some sort. The standard one on the door is only really for the steel wheels, since a Boost is significantly heavier you'll warp the door, damage the hinges / latch and eventually the back window will randomly smash one day... that's what mine did! |
