Home > Off Topic > caravan luck (or lack of)
Page 1 of 4 1234>
Caterham
So went away the weekend and borrowed the parents caravan which was spotless until I borrowed it last year and bashed the rear corner....managed to get it repaired before they returned from their holidays Embarassed
Anyway borrowed it again this weekend and guess what........?
Yep bashed the other rear corner Sad
Sat nav sent me down a small lane so was only going slow when I went through a puddle that almost spanned the whole lane....BASH Wtf! stopped had a look and hey presto the back corner was bashed and yet couldn't see what it had hit.....in some puddle was a wheel trim and wheel arch liner.....put 2 and 2 together and only explanation I can think of was almighty pot hole.... caravan wheel dropped into it and back of van hit floor!!!! Blast.
Post #333698 26th May 2014 12:15pm
T1G UP
id of burned the 110 and the caravan there and then if i was you. get a saloon car and a hotel next time
Post #333718 26th May 2014 2:43pm
K9F
I believe you may be able to claim off the relevant council if it is designated an adopted road and not private. Worth perhaps enquiring. You could fix it.........
Then burn it! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333721 26th May 2014 2:56pm
ericvv
Post #333734 26th May 2014 3:44pm
gilarion
When you said the back of the caravan is damaged on both corners is it constructed from metal of glass fibre reinforced plastic. If the latter you may end up having to have the whole back panel replaced, thats a £2000.00 Job Shocked
If metal they may be able to to run a strip down to repair depending if it is one piece or if there is a join along the back.
Post #333738 26th May 2014 3:49pm
munch90
maybe you need a off road caravan like this
eBay item number:
eBay Item No. 251540617921
Post #333745 26th May 2014 3:58pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
that's not a caravan. Mine has a wash room bigger than that. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #333755 26th May 2014 4:29pm
gilarion
eBay item number:
What that needs is a a motorbike attaching to it, what a brilliant sidecar it would make Smile
Post #333772 26th May 2014 5:21pm
Caterham
Someone has chucked some tyres in the road now to prevent any more problems....
Anyhow I forgot the punch line.... can anyone recommend someone close to b'ham to fix the damage....minor damage to fibre glass / abs but the alloy channel needs some serious bending.
Got photos and will see where I get with claim on council.
Post #333775 26th May 2014 5:25pm
gilarion
Looking at that awning, if a gust of wind got under that, I think you would not just have an Off Road Caravan but an off the ground caravan as well. Laughing
[URL=][/URL]
Post #333777 26th May 2014 5:31pm
ARC99
Alloy channel? Do you mean the chassis of the caravan if so its a possible right off. Don't make old people mad.
Richard
Post #333796 26th May 2014 7:03pm
ickle
Is the caravan level or nose high when hitched? Could be the reason you've wiped it out (twice!)
Post #333797 26th May 2014 7:11pm
munch90
channel the awning slots into ?
Post #333804 26th May 2014 7:27pm
Caterham
Yes. Channel awning slots into not chassis rails.
Post #333808 26th May 2014 7:54pm
Caterham
Ickle. Yes van is a little nose up but much.
This time I feel it was purely bad luck and suspect the pot hole is like a plunge pool. Last time was down to a lack of experience...went over a grass verge which I knew def could take in its stride but didn't give due thought to what I was pulling Embarassed
Post #333809 26th May 2014 7:58pm
Page 1 of 4 1234>
