Home > Technical > Light switch??
jimbob7
Light switch??
After fitting the Landreiziger headlamp loom, new crystal headlamps,Osram nightbreakers,cheapo led front sidelight bulbs,I now think my light switch is broke Rolling Eyes Banging Head .
In position 1;I get dipped beam as well as sidelight, (note,dipped beam NOT dim-dip).
Position 2; exactly the same,dipped beam and sidelights.
Main beam works normally and I can flash whatever the switch position maybe.
Probably not used my headlamps since February,lol.I tested the lights at the time I fitted them and all was well,it seems to have happened today when I switched my sidelights on coz of heavy rain.
If it is the light switch?? I assume Lucas (Prince of Darkness,lol) is the one to go for?? Or could it be the cheapo led bulbs??
FWIW,for the headlamp loom I used the live feed from the alternator and earthed it to the cylinder head. Pov.spec,ftw. 2006, 110,TD5.
Post #333310 24th May 2014 7:20pm
munch90
has yours got or had dim dip fitted
Post #333317 24th May 2014 7:44pm
jimbob7
Er,yes and no,I had dim dip recently,but assumed it's a fault causing dim-dip or a fault that stopped it working,mostly I don't have dim-dip Confused . Pov.spec,ftw. 2006, 110,TD5.
Post #333319 24th May 2014 7:58pm
munch90
think your best off to disconnect the dim dip first
Post #333321 24th May 2014 8:03pm
jimbob7
Just simply unplug the resistor??As simple as these pics suggest,or remove relay behind binnacle and rewire the relay holder?? Cheers.
http://www.defender2.net/forum/topic9328-30.html
Post #333323 24th May 2014 8:25pm
