![]() | Home > Technical > Light switch?? |
has yours got or had dim dip fitted
Er,yes and no,I had dim dip recently,but assumed it's a fault causing dim-dip or a fault that stopped it working,mostly I don't have dim-dip
think your best off to disconnect the dim dip first
Just simply unplug the resistor??As simple as these pics suggest,or remove relay behind binnacle and rewire the relay holder?? Cheers.
http://www.defender2.net/forum/topic9328-30.html ![]() Click image to enlarge ![]() Click image to enlarge Pov.spec,ftw. 2006, 110,TD5. |
