![]() | Home > Maintenance & Modifications > Anyone tried masai rear window tinted set? |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 199 ![]() ![]() ![]() |
As above.
Looking to fit side windows to 90 hardtop. Seen "masai" rear side windows in tint. Anyone used them / any good? Wil |
Different Masai ones are depicted in this thread.....
![]() I just recently sold my take outs too. May be worth putting up a wanted request? http://www.defender2.net/forum/topic22833....landyglass If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I have some Masai 2nd row glass fitted.
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 ![]() ![]() ![]() |
I cut a pair of Masai windows into my hardtop, they are excellent quality and well made, and for the price you can't go wrong, the only negative I would say was the template that you get was alittle out, but it just took a little extra trimming
hawky Member Since: 18 Mar 2014 Location: Yalding Posts: 5 ![]() ![]() ![]() |
I have a defender CSW 110 ('05) and need to replace the sliding windows with a metal sheet over the whole side. But how do the windows actually come out. Have removed the interior fixing spacers, as as there are no rivets (like previous models, as newer models have no external rubbers),and there appears to be just a foam seal around the outside - thought that with just a little brute force they would now come out - NO.
Is there a mastic seal as well ? was hoping to remove them, measure to fit new panels, paint & install this w/e. ![]() |
Duffs Member Since: 19 Apr 2014 Location: Northumbria/ Cumbria/ Borders Posts: 48 ![]() ![]() |
![]() I am impressed with mine, love them. 2001 DEF TD5 County |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hawky, I'm sure they're bonded in, I was struggling to have the side glass in my 110CSW tinted as a lot of the companies didn't want to have to remove the fames in case of damage. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Jomara, you don't need to have them taken out I didn't and the job was very good.
From another tinting thread..... ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Just had a look at your thread K9F.
I tried all the recommended companies in Glasgow, most wouldn't touch it, one wanted me remove the rear windows and alpine lights for them!! The only one who agreed to take it on and do the complete job was Pentagon total cost of £240. I'll need to ask Gary how they do it, need to admit I'm not 100% if they removed the glass, the other guys gave me war and peace on what they wouldn't do and how they wouldn't be responsible for damage or reinstallation, best of it was they wanted more than Pentagon!! 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
It is an arduos job removing the slider windows as they are bonded in. I eventually had mine removed when I had my Landyglass fitted. As the windows had potentially been sold to a fellow forum member I wanted them removed carefully and in one piece. They did have to work quite hard to achieve this.
For the sake of tinting I personally would insist for them NOT to be removed. A scratch or over-zealous 'dig' in the framework could result in corrosion in a few months/years time. Best not to potentially compromise the framework sealant in my view. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Sounds like a total pain!! I can only assume that it was done in situ as it was only away for the day. I was amazed when the first company I called told me that they wanted the full window out and it was up to me to sort it out!!! Only wish I had got an Orkney Grey after seeing Discocuzzy's pictures
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Jomara, try Advanced Window Tinting, 636 South st, Glasgow
Pentagon did my 110 SW back in 2009 (since sold), however I have used the guy in South Street for other vehicles and he is pretty good, he would probably do the tinting no problem, and his prices are good. Mike |
Cheers Mike I'll give him a call
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
If you want windows tinting done properly you have to remove the sliders from the frame,which means the frames have to be removed.and if you have a puma not many companies can remove them without damaging the panels.
