Home > Technical > Three(3) squeeks when switching off? |
egr valve
19th May 2014 7:18pm |
egr valve self cleaning - perfectly normal (if you have an egr valve)
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
I had mine replaced recently under warranty. Quiet as a mouse again.
I've read that it is because it dries out. Don't think it's really an issue, just a bit noisy. If it's true, I would very much like to know how to prevent and/or solve it when it happens. |
19th May 2014 7:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20281 |
They usually do it when older I think, mine doesn't squeak at all only do the cleaning cycles.
19th May 2014 7:41pm |
inside the egr valve are a electric motor and gearbox that drive the spindle opening and closing the valve , the trouble is the black sooty smoke gets passed the spindle and fills gearbox with carbon and dries all the grease out and just clogs everything and in the end seizes them solid also inside there are position indicators that get covered in soot , I know this because I have broke them open to see what's inside
sometimes you can see traces of black soot around the joint on the valve normally where the clips are that hold the gearbox cover on if you can see this it's knackered Last edited by munch90 on 19th May 2014 9:06pm. Edited 1 time in total |
19th May 2014 7:59pm |
^^ fit for purpose ?
19th May 2014 9:01pm |
Edskoi Member Since: 13 Aug 2013 Location: KZN Posts: 2 |
Thanks for info guys, Based upon your replies, especially soot build-up, I have decided to only use low sulphur Diesel (50 ppm instead of 500 ppm) is now available in South Africa. Edskoi
20th May 2014 5:21pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2632 |
Edskoi, only use 50ppm.
Also, if the EGR self-cleaning is screeching, have it seen to. When the EGR was still active on mine, I found that using 2-stroke oil made it quieter. this is what a normal EGR cycle sounds like: -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th May 2014 5:46pm |
Premium fuel is all I use, no supermarket stuff at all ever.
20th May 2014 6:25pm |
