Home > Technical > Three(3) squeeks when switching off?
Edskoi
South Africa 2011 Defender 90 Puma 2.4 HT Alpine White
Over the past 2 weeks, when switching off my Defender (Puma 90 Diesel with 2.8 Ford Transit engine), I hear 3 or 4 loud squeeks (Like some unoiled plates rubbing together. It appears to come from somewhere near the top RH side of the engine block. Any ideas as to cause? Edskoi
Post #332113 19th May 2014 8:14pm
munch90
egr valve
Post #332114 19th May 2014 8:18pm
egr valve self cleaning - perfectly normal (if you have an egr valve)
Post #332115 19th May 2014 8:18pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I had mine replaced recently under warranty. Quiet as a mouse again.
I've read that it is because it dries out. Don't think it's really an issue, just a bit noisy.
If it's true, I would very much like to know how to prevent and/or solve it when it happens.
Post #332116 19th May 2014 8:35pm
They usually do it when older I think, mine doesn't squeak at all only do the cleaning cycles.
Post #332117 19th May 2014 8:41pm
munch90
inside the egr valve are a electric motor and gearbox that drive the spindle opening and closing the valve , the trouble is the black sooty smoke gets passed the spindle and fills gearbox with carbon and dries all the grease out and just clogs everything and in the end seizes them solid also inside there are position indicators that get covered in soot , I know this because I have broke them open to see what's inside
sometimes you can see traces of black soot around the joint on the valve normally where the clips are that hold the gearbox cover on if you can see this it's knackered
Post #332123 19th May 2014 8:59pm
^^ fit for purpose Shocked ?
Post #332141 19th May 2014 10:01pm
Edskoi
Thanks for info guys, Based upon your replies, especially soot build-up, I have decided to only use low sulphur Diesel (50 ppm instead of 500 ppm) is now available in South Africa. Edskoi
Post #332343 20th May 2014 6:21pm
Naks
Edskoi, only use 50ppm.
Also, if the EGR self-cleaning is screeching, have it seen to.
When the EGR was still active on mine, I found that using 2-stroke oil made it quieter.
this is what a normal EGR cycle sounds like:  --
Post #332354 20th May 2014 6:46pm
Premium fuel is all I use, no supermarket stuff at all ever.
Post #332371 20th May 2014 7:25pm
