Home > Maintenance & Modifications > Nato hitch..
xtreme
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Sumatra Black
Nato hitch..
confused.com!!!
Have searched and read and confused with the various posts....???
I have a 2012 110 defender, currently fitted with a NAS rear step.
Purchasing a sankey trailer (with rotating eye) so I need a nato hitch with a fixed hitch for this.
So far so good?
But, I also use a bike rack/standard trailer onto a standard 50mm ball fitting (nas too hich for standard trailer!), so considering options and removing nas step and refitting standard tow equipment supplied new with vehicle.
I want an easy switch between the two options, and different heights required so looking at fitting a LR Dixon Bate adjustable tow bar?
Presumably I buy 2 slider pieces, one for 50mm and one for Nato? Re the NATO is this a standard fitment or do I need a special slider / modify?
So many options on ebay/websites etc - want to ensure I get the right one, thats properly rated etc?
Any help much appreciated - with links preferably.
Thanks
Post #331651 17th May 2014 8:24pm
JWL
That's how I work with mine, Dixon Bate slide attachment on the back and one saddle with a Nato hitch and the other with a pin/ball hitch and just swop over as needed. Most of the time they are in the back so I'm not catching my shins all the time. There are saddles that are drilled ready for Nato hitches and ordinary 2 hole standard hitches all on the same saddle.
I haven't got any pictures to hand but they are quite commonly found(but as usual never when you want one!) on ebay, autojumbles and by asking around.
Post #331655 17th May 2014 8:40pm
That's certainly the way I did it:
 Darren
Post #331659 17th May 2014 9:01pm
shaggydog
Dixon Bate Slider is the way to go.
Only thing I can add is if you can afford it, go for the double pin version as it rattles less and in my opinion is better as it spreads your load over 2 pins rather than a single pin, though its all heavy stuff so wont make too much difference.
Post #331663 17th May 2014 9:09pm
me too, I have nato hitch, bike rack and std tow ball - easy
remember to remove them when not in use as some thieving b@strd will remove it for you
Post #331699 18th May 2014 6:24am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
From what I have read and been told, you cannot tow a sankey via NATO hitch on vehicles built after 1997 (not 1998), as this form of tow hitch is rendered illegal for civilian road use after that year, due to not having the correct type approval.
Edit: If all Defenders are now commercial, I may be entirely wrong on this... 1998 110 300Tdi White Hard Top
Post #331774 18th May 2014 1:57pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
N1 or commercial vehicles are exempt from the type approval of towbars as is anything before August 98. M1 vehicles or passenger cars need type approved equipment and it is illegal to modify such equipment. As I understand it all defenders after 2011 are n1 regardless of the number of seats. Rhubarb and custard let fly with their secret weapon.
Post #331792 18th May 2014 3:39pm
