Home > Technical > Triming a Number Plate |
there is a regulation size , but as long it can be read ok ???
lots of bikes have smaller plates |
17th May 2014 2:07pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I put the front reg plate on the vent flap one of my previous Defenders, as far as I recollect there needs to be a minimum of 11mm all around the outside of the letters/numbers to remain legal, so there should be room unless you have a particularly long number
17th May 2014 3:27pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Are right cheer's Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
17th May 2014 3:55pm |
Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96 |
11mm border is correct.
Page 9 on this has dimension details. https://www.gov.uk/government/uploads/syst...067666.pdf |
17th May 2014 6:17pm |
GreigP Member Since: 13 Apr 2014 Location: aberdeenshire Posts: 18 |
Nice one I have just fitted the same, and was looking to attach the plate to my roof rack...but the metal plate holder is just a tad shorter than the standard reg....so I was also thinking of trimming.. will make sure I leave 11mm cheers, g |
17th May 2014 6:22pm |
There it is, plenty of room, and you can read it while wading
Click image to enlarge |
17th May 2014 6:41pm |
Nice one i will do that Graham
17th May 2014 11:48pm |
jhnstap Member Since: 01 Apr 2013 Location: Bournemouth Posts: 73 |
Got one of these fitted you may be able to adapt
http://www.bushranger.com.au/x_bar.php I do my thing and you do yours. I am not in this world to live up to your expectations, and you are not in this world to live up to mine |
18th May 2014 8:29am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
18th May 2014 8:43pm |
